Regularizing the ODF estimate with the Laplace-Beltrami operator in 3D Polarized Light Imaging - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2017
3D-Polarized Light Imaging (3D-PLI) is an optical approach that utilizes the birefringence in postmortem organs (brain/ heart) to map their spatial fiber structure at a submillimeter resolution. Recently, Axer et al. proposed a strategy to bridge it to relatively low diffusion MRI spatial resolution by introducing an estimate of the fiber orientation distribution functions (pliODF) from high-resolution 3D-PLI vector data. However, this method introduces angular errors by discretizing the directional histogram (DH), which limits the spherical harmonics (SH) expansion order. In this work, we propose to improve the angular resolution by making use of the Laplace-Beltrami (LB) operator to regularize the SH coefficients which define the fiber ODF at higher orders.
CoBCoM2.pdf (2.16 Mo) Télécharger le fichier
hal-01659253 , version 1 (08-12-2017)
  • HAL Id : hal-01659253 , version 1
Abib O. Y. Alimi, Samuel Deslauriers-Gauthier, Rachid Deriche. Regularizing the ODF estimate with the Laplace-Beltrami operator in 3D Polarized Light Imaging. CoBCoM 2017 - Computational Brain Connectivity Mapping Winter School Workshop, Nov 2017, Juan-les-Pins, France. , pp.1. ⟨hal-01659253⟩
211 Consultations
124 Téléchargements
