A theoretical study of a simplified air-sea coupling problem including turbulent parameterizations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper we study a simplified mathematical model representative of air-sea coupling. This model incorporates parameterizations of the turbulent boundary layers as used in realistic models. We show that even if simple equations like the one-dimensional stationary heat equation are considered the presence of parameterizations renders the problem extremly complex to study and the unicity of solutions is no longer guaranteed. We motivate and describe a coupling algorithm which ensures that a unique physically sound solution is obtained.
2017-03_eccomas.pdf (544.87 Ko) Télécharger le fichier
hal-01659443 , version 1 (11-12-2017)
  • HAL Id : hal-01659443 , version 1
Charles Pelletier, Florian Lemarié, Eric Blayo. A theoretical study of a simplified air-sea coupling problem including turbulent parameterizations. COUPLED PROBLEMS 2017 - VII International Conference on Computational Methods for Coupled Problems in Science and Engineering, Jun 2017, Rhodes, Greece. pp.38-49. ⟨hal-01659443⟩
662 Consultations
196 Téléchargements
