New interface
Conference papers
Tridimensional model coupling using Schwarz methodology - Application to a water intake of a hydroelectric plant
Mehdi Pierre Daou 1 Olivier Bertrand 1 Eric Blayo 2 Antoine Rousseau 3
2 AIRSEA - Mathematics and computing applied to oceanic and atmospheric flows
Inria Grenoble - Rhône-Alpes, Grenoble INP - Institut polytechnique de Grenoble - Grenoble Institute of Technology, UGA [2016-2019] - Université Grenoble Alpes [2016-2019], LJK - Laboratoire Jean Kuntzmann
3 LEMON - Littoral, Environment: MOdels and Numerics
CRISAM - Inria Sophia Antipolis - Méditerranée , IMAG - Institut Montpelliérain Alexander Grothendieck, HSM - Hydrosciences Montpellier
Abstract : Progress has been performed for decades, in terms of physical knowledge, numerical techniques and computer power, that allows to address more and more complex simulations. For many applications, engineers have to implement complex "modeling systems", coupling several models and softwares, representing various parts of the physical system. We address in this article model coupling techniques using Schwarz's methodology, which is based on domain decomposition methods. The basic principle is to reduce the resolution of a complex problem into several simpler sub-problems, thanks to an iterative algorithm. These methods are particularly well suited for industrial codes, since they are very few intrusive. We firstly discuss a coupling test case between two monophasic/diphasic tridimensional models, using Telemac-Mascaret and OpenFOAM software systems. Secondly, we analyze such a coupling for an operational engineering study of a water intake for a hydroelectric plant and a short comparison with physical model results.
Complete list of metadata
https://hal.inria.fr/hal-01659455
Contributor : Eric Blayo Connect in order to contact the contributor
Submitted on : Thursday, December 14, 2017 - 6:34:01 PM
Last modification on : Friday, August 5, 2022 - 10:45:39 AM
File
simhydro2017_articleV5.pdf
Identifiers
  • HAL Id : hal-01659455, version 1
Citation
Mehdi Pierre Daou, Olivier Bertrand, Eric Blayo, Antoine Rousseau. Tridimensional model coupling using Schwarz methodology - Application to a water intake of a hydroelectric plant. Simhydro 2017, Jun 2017, Sophia-Antipolis, France. pp.14 - 16. ⟨hal-01659455⟩
Share
Metrics
Record views
312
Files downloads
215
