Analysis of ocean-atmosphere coupling algorithms: consistency and stability issues - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper is focused on the numerical and computational issues associated to ocean-atmosphere coupling. It is shown that usual coupling methods do not provide the solution to the correct problem, but to an approaching one since they are equivalent to performing one single iteration of an iterative coupling method. The stability analysis of these ad-hoc methods is presented, and we motivate and propose the adaptation of a Schwarz domain decomposition method to ocean-atmosphere coupling to obtain a stable and consistent coupling method.
hal-01659459 , version 1 (08-12-2017)
Florian Lemarié, Eric Blayo, Laurent Debreu. Analysis of ocean-atmosphere coupling algorithms: consistency and stability issues. 15th International Conference on Computational Sciences, Jun 2015, Reykjavik, Iceland. pp.2066-2075, ⟨10.1016/j.procs.2015.05.473⟩. ⟨hal-01659459⟩
184 Consultations
0 Téléchargements
