Stability interval for time-varying delay systems, 49th IEEE Conference on Decision and Control (CDC), pp.1017-1022, 2010. ,
DOI : 10.1109/CDC.2010.5717071
Invoking Halanay inequality to conclude on closed-loop stability of a process with input-varying delay, Proceedings of the 10th IFAC Workshop on Time Delay Systems, pp.266-271 ,
URL : https://hal.archives-ouvertes.fr/hal-00755249
Convex conditions for robust stability analysis and stabilization of linear aperiodic impulsive and sampled-data systems under dwell-time constraints, Automatica, vol.49, issue.11, pp.49-3449, 2013. ,
DOI : 10.1016/j.automatica.2013.08.022
Convex conditions for robust stabilization of uncertain switched systems with guaranteed minimum and mode-dependent dwell-time, Systems and Control Letters, pp.63-72, 2015. ,
Affine Characterizations of Minimal and Mode-Dependent Dwell-Times for Uncertain Linear Switched Systems, IEEE Transactions on Automatic Control, vol.58, issue.5, pp.1304-1310, 2013. ,
DOI : 10.1109/TAC.2012.2220031
Dwell-time computation for stability of switched systems with time delays, IET Control Theory & Applications, vol.7, issue.10, pp.1422-1428, 2013. ,
DOI : 10.1049/iet-cta.2011.0749
URL : https://hal.archives-ouvertes.fr/hal-00935511
An Extension of LaSalle's Invariance Principle and Its Application to Multi-Agent Consensus, IEEE Transactions on Automatic Control, vol.53, issue.7, pp.53-1765, 2008. ,
DOI : 10.1109/TAC.2008.928332
A Nonconservative LMI Condition for Stability of Switched Systems With Guaranteed Dwell Time, IEEE Transactions on Automatic Control, vol.57, issue.5, pp.1297-1302, 2012. ,
DOI : 10.1109/TAC.2011.2174665
Supervisory control design for networked systems with time-varying communication delays, Nonlinear Analysis: Hybrid Systems, pp.94-110, 2013. ,
On robust stability of linear neutral systems with time-varying delays, IMA Journal of Mathematical Control and Information, vol.25, issue.4, pp.393-407, 2008. ,
DOI : 10.1093/imamci/dnn003
Introduction to Time-Delay Systems: Analysis and Control, 2014. ,
DOI : 10.1007/978-3-319-09393-2
Stability and Stabilization of Continuous???Time Switched Linear Systems, SIAM Journal on Control and Optimization, vol.45, issue.5, pp.1915-1930, 2006. ,
DOI : 10.1137/050646366
Differential Equations, Stability, Oscillations, Time Lags, 1966. ,
Uniform Stability of Switched Linear Systems: Extensions of LaSalle's Invariance Principle, IEEE Transactions on Automatic Control, vol.49, issue.4, pp.470-482, 2004. ,
DOI : 10.1109/TAC.2004.825641
Lyapunov conditions for input-to-state stability of impulsive systems, Automatica, vol.44, issue.11, pp.44-2735, 2008. ,
DOI : 10.1016/j.automatica.2008.03.021
Stability of switched systems with average dwell-time, Proceedings of the 38th IEEE Conference on Decision and Control (Cat. No.99CH36304), pp.2655-2660, 1999. ,
DOI : 10.1109/CDC.1999.831330
Switching controller for stabilization of linear systems with switched time-varying delays, Proceedings of the 48h IEEE Conference on Decision and Control (CDC) held jointly with 2009 28th Chinese Control Conference, pp.7923-7928, 2009. ,
DOI : 10.1109/CDC.2009.5400666
URL : https://hal.archives-ouvertes.fr/inria-00419360
Nonlinear Systems On dwell time minimization for switched delay systems, 2002. ,
Uniform Asymptotic Stability of Nonlinear Switched Systems With an Application to Mobile Robots, IEEE Transactions on Automatic Control, vol.53, issue.5, pp.1235-1252, 2008. ,
DOI : 10.1109/TAC.2008.923688
Switching in Systems and Control, 2003. ,
DOI : 10.1007/978-1-4612-0017-8
Hybrid Dynamical Systems with Finite Memory, Recent Results on Nonlinear Delay Control Systems Advances in Delay and Dynamics Series 4, pp.261-273, 2016. ,
DOI : 10.1007/978-3-319-18072-4_13
Invariance principles for hybrid systems with memory, Nonlinear Analysis: Hybrid Systems, pp.130-138, 2016. ,
On converse Lyapunov theorems for ISS and iISS switched nonlinear systems, Systems & Control Letters, vol.42, issue.1, pp.47-53, 2001. ,
DOI : 10.1016/S0167-6911(00)00079-7
An extension of LaSalle's invariance principle for switched systems, Systems & Control Letters, vol.55, issue.5, pp.376-384, 2006. ,
DOI : 10.1016/j.sysconle.2005.07.009
Trajectory Based Approach for the Stability Analysis of Nonlinear Systems with Time Delays, IEEE Transactions on Automatic Control, vol.60, issue.6, pp.1716-1721, 2015. ,
DOI : 10.1109/TAC.2014.2361593
URL : https://hal.archives-ouvertes.fr/hal-01100347
Reduction model approach for systems with a time-varying delay, 2015 54th IEEE Conference on Decision and Control (CDC), pp.7723-7727, 2015. ,
DOI : 10.1109/CDC.2015.7403440
URL : https://hal.archives-ouvertes.fr/hal-01248071
Extension of Razumikhin's theorem for time-varying systems with delay, 2016 American Control Conference (ACC), pp.84-88 ,
DOI : 10.1109/ACC.2016.7524896
Further results on input-to-state stability for nonlinear systems with delayed feedbacks, Automatica, vol.44, issue.9, pp.44-2415, 2008. ,
DOI : 10.1016/j.automatica.2008.01.024
URL : https://hal.archives-ouvertes.fr/hal-00857808
Stability analysis for systems with timevarying delay: trajectory based approach, Proceedings of the 54th IEEE Conference on Decision and Control, pp.1811-1816, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01248070
Stability analysis of switched systems with timevarying discontinuous delays, Proceedings of the American Control Conference, pp.5177-5181 ,
URL : https://hal.archives-ouvertes.fr/hal-01660128
A look at fast varying and state dependent delays from a system theory point of view, 2011. ,
Supervisory control of families of linear set-point controllers - Part I. Exact matching, IEEE Transactions on Automatic Control, vol.41, issue.10, pp.1413-1431, 1996. ,
DOI : 10.1109/9.539424
Exponential stability of impulsive systems with application to uncertain sampled-data systems, Systems & Control Letters, vol.57, issue.5, pp.378-385, 2008. ,
DOI : 10.1016/j.sysconle.2007.10.009
Stabilization in the Sample-and-Hold Sense of Nonlinear Retarded Systems, SIAM Journal on Control and Optimization, vol.52, issue.5, pp.3053-3077, 2014. ,
DOI : 10.1137/130943182
Mathematical Control Theory, 1998. ,
DOI : 10.1007/978-1-4612-0577-7
Stability Theory of Switched Dynamical Systems, Communications and Control Engineering Series, 2011. ,
DOI : 10.1007/978-0-85729-256-8
Stability of Time-Delay Feedback Switched Linear Systems, IEEE Transactions on Automatic Control, vol.55, issue.10, pp.2385-2390, 2010. ,
DOI : 10.1109/TAC.2010.2053750
Stability of switched nonlinear systems with delay and disturbance, Automatica, vol.69, pp.69-78, 2016. ,
DOI : 10.1016/j.automatica.2016.02.015
URL : https://hal.archives-ouvertes.fr/hal-01391683
A Converse Lyapunov Theorem for Linear Parameter-Varying and Linear Switching Systems, SIAM Journal on Control and Optimization, vol.44, issue.1, pp.210-239, 2005. ,
DOI : 10.1137/S0363012903434790
Delay-dependent criteria for robust stability of time-varying delay systems, Automatica, pp.40-1435, 2004. ,
Stabilisation of time-delay switched systems with constrained switching signals and its applications in networked control systems, IET Control Theory & Applications, vol.4, issue.10, pp.2120-2128, 2010. ,
DOI : 10.1049/iet-cta.2009.0016
Periodical stabilization of switched linear systems, Journal of Computational and Applied Mathematics, vol.181, issue.1, pp.176-187, 2005. ,
DOI : 10.1016/j.cam.2004.11.026
Stability analysis of switched time-delay systems Robust stabilization of parameter varying time delay systems by switched controllers, SIAM Journal on Control and Optimization Applied and Computational Mathematics, pp.47-936, 2008. ,
On stabilization of switched nonlinear systems with unstable modes, Systems and Control Letters, pp.703-708, 2009. ,
Razumikhin and Krasovskii stability theorems for time-varying time-delay systems, Automatica, vol.71, pp.71-281, 2016. ,
DOI : 10.1016/j.automatica.2016.04.048
