Stability Analysis of Switched Systems with Time-Varying Discontinuous Delays
A new technique is proposed to ensure global asymptotic stability for nonlinear switched time-varying systems with time-varying discontinuous delays. It uses an adaptation of Halanay's inequality to switched systems and a recent trajectory based technique. The result is applied to a family of linear time-varying systems with time-varying delays.
