Control Using Logic-Based Switching, 1997. ,
DOI : 10.1007/978-1-4471-3061-1_4
URL : http://entity.eng.yale.edu/controls/1998/a.ps
Switched Linear Systems: Control and Design, 2005. ,
DOI : 10.1007/1-84628-131-8
Switching robust controllers for automatic regulation of postoperative hypertension using vasodilator drug infusion rate, Proceedings of IFAC Workshop on Linear Parameter Varying Systems, pp.224-229, 2015. ,
Design of a switched robust control scheme for drug delivery in blood pressure regulation, Proceedings of IFAC Workshop on Time Delay Systems, pp.252-257, 2016. ,
Basic problems in stability and design of switched systems, IEEE Control Systems Magazine, vol.19, issue.5, pp.59-70, 1999. ,
DOI : 10.1109/37.793443
Output-feedback H??? control of systems over communication networks using a deterministic switching system approach, Automatica, vol.40, issue.7, pp.1205-1212, 2004. ,
DOI : 10.1016/j.automatica.2004.01.024
Design and Stability Criteria of Networked Predictive Control Systems With Random Network Delay in the Feedback Channel, IEEE Transactions on Systems, Man and Cybernetics, Part C (Applications and Reviews), vol.37, issue.2, pp.173-184, 2007. ,
DOI : 10.1109/TSMCC.2006.886987
Variable-Rate Noncoherent M-FSK Modulation for Power Limited Systems Over Nakagami- Fading Channels, IEEE Transactions on Wireless Communications, vol.3, issue.4, pp.1295-1304, 2004. ,
DOI : 10.1109/TWC.2004.830851
Solid-State Circuit Breakers and Current Limiters for Medium-Voltage Systems Having Distributed Power Systems, IEEE Transactions on Power Electronics, vol.19, issue.5, pp.1333-1340, 2004. ,
DOI : 10.1109/TPEL.2004.833454
URL : http://esrdc.mit.edu/library/ESRDC_library/Meyer-Solid-State-2004.pdf
Stability and stabilization of switched linear systems with state delay, Proceedings of Mathematical Theory of Networks and Systems Conference, 2004. ,
Stabilization of switched linear systems with time-delay in detection of switching signal, Journal of Mathematical Analysis and Applications, vol.305, issue.1, pp.277-290, 2005. ,
DOI : 10.1016/j.jmaa.2004.11.043
Stabilization of Arbitrary Switched Linear Systems With Unknown Time-Varying Delays, IEEE Transactions on Automatic Control, vol.51, issue.10, pp.1668-1674, 2006. ,
DOI : 10.1109/TAC.2006.883030
URL : https://hal.archives-ouvertes.fr/hal-00121714
Stability of a class of linear switching systems with time delay, IEEE Transactions on Circuits and Systems, vol.53, issue.2, pp.384-393, 2006. ,
Stability and <mml:math altimg="si1.gif" display="inline" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd"><mml:msub><mml:mrow><mml:mi>L</mml:mi></mml:mrow><mml:mrow><mml:mn>2</mml:mn></mml:mrow></mml:msub></mml:math>-gain analysis for switched delay systems: A delay-dependent method, Automatica, vol.42, issue.10, pp.1769-1774, 2006. ,
DOI : 10.1016/j.automatica.2006.05.007
Stability analysis for linear switched systems with time-varying delay, IEEE Transactions on Systems, Man, and Cybernetics-Part B: Cybernatics, vol.38, issue.2, pp.528-533, 2008. ,
Switched Time-Delay Systems: Stability and Control, 2010. ,
Stability of Time-Delay Feedback Switched Linear Systems, IEEE Transactions on Automatic Control, vol.55, issue.10, pp.2385-23901422, 2010. ,
DOI : 10.1109/TAC.2010.2053750
Stabilization of positive switched systems with time-varying delays under asynchronous switching Robust stabilization of parameter varying time delay systems by switched controllers, International Journal of Control, Automation and Systems Applied and Computational Mathematics, vol.12, issue.131, pp.939-94731, 2014. ,
NP-Hardness of Some Linear Control Design Problems, SIAM Journal on Control and Optimization, vol.35, issue.6, pp.2118-2127, 1997. ,
DOI : 10.1137/S0363012994272630
Trajectory Based Approach for the Stability Analysis of Nonlinear Systems with Time Delays, IEEE Transactions on Automatic Control, vol.60, issue.6, pp.1716-1721, 2015. ,
DOI : 10.1109/TAC.2014.2361593
URL : https://hal.archives-ouvertes.fr/hal-01100347
Stability analysis for systems with time-varying delay: Trajectory based approach, 2015 54th IEEE Conference on Decision and Control (CDC), pp.1811-1816, 2015. ,
DOI : 10.1109/CDC.2015.7402473
URL : https://hal.archives-ouvertes.fr/hal-01248070
Dynamic output feedback stabilization of switched linear systems with delay via a trajectory based approach, 2017. ,
