Observer with small gains in the presence of a long delay in the measurements - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
For a particular family of systems, we construct observers in the case where the measured variables are affected by the presence of a point-wise time-varying delay. The key feature of the proposed observers is that the size of their gains is proportional to the inverse of the largest value taken by the delay. The main result is first presented in the case of linear chain of integrators and next is extended to nonlinear systems with specific nonlinearities. A numerical example is provided to show the validity and effectiveness of the proposed observers.
Automatique
cdcalizemouche.pdf (408.2 Ko) Télécharger le fichier
hal-01660130 , version 1 (10-12-2017)
Frédéric Mazenc, Ali Zemouche, Silviu-Iulian Niculescu. Observer with small gains in the presence of a long delay in the measurements. 56th IEEE Conference on Decision and Control, CDC 2017, Dec 2017, Melbourne, Australia. pp.4327-4332, ⟨10.1109/cdc.2017.8264297⟩. ⟨hal-01660130⟩
432 Consultations
168 Téléchargements
