Abstract : This paper studies the problem of document image classification. More specifically, we address the classification of documents composed of few textual information and complex background (such as identity documents). Unlike most existing systems, the proposed approach simultaneously locates the document and recognizes its class. The latter is defined by the document nature (passport, ID, etc.), emission country, version, and the visible side (main or back). This task is very challenging due to unconstrained capturing conditions, sparse textual information, and varying components that are irrelevant to the classification, e.g. photo, names, address, etc. First, a base of document models is created from reference images. We show that training images are not necessary and only one reference image is enough to create a document model. Then, the query image is matched against all models in the base. Unknown documents are rejected using an estimated quality based on the extracted document. The matching process is optimized to guarantee an execution time independent from the number of document models. Once the document model is found, a more accurate matching is performed to locate the document and facilitate information extraction. Our system is evaluated on several datasets with up to 3042 real documents (representing 64 classes) achieving an accuracy of 96.6%.
