Fast and Slow Contrast Adaptation in Retinal Circuitry, Neuron, vol.36, issue.5, pp.909-919, 2002. ,
DOI : 10.1016/S0896-6273(02)01050-4
A CNN framework for modeling parallel processing in a mammalian retina, International Journal of Circuit Theory and Applications, vol.65, issue.2-3, pp.2-3, 2002. ,
DOI : 10.1016/0042-6989(79)90113-5
Action potentials from the frog's retina, The Journal of Physiology, vol.119, issue.1, pp.58-68, 1953. ,
DOI : 10.1113/jphysiol.1953.sp004828
Cellular Basis for Contrast Gain Control over the Receptive Field Center of Mammalian Retinal Ganglion Cells, Journal of Neuroscience, vol.27, issue.10, pp.2636-2645, 2007. ,
DOI : 10.1523/JNEUROSCI.4610-06.2007
Dynamics of primate P retinal ganglion cells: Responses to chromatic and achromatic stimuli, Journal of Physiology, vol.519, issue.3, pp.775-790, 1999. ,
Contrast gain control in the primate retina: P cells are not X-like, some M cells are, Visual Neuroscience, vol.8, issue.5, pp.483-486, 1992. ,
The structure and precision of retinal spike trains, Proceedings of the National Academy of Sciences, vol.49, issue.2, pp.5411-5416, 1997. ,
DOI : 10.1088/0954-898X/7/2/013
The Suppressive Field of Neurons in Lateral Geniculate Nucleus, Journal of Neuroscience, vol.25, issue.47, pp.10844-10856, 2005. ,
DOI : 10.1523/JNEUROSCI.3562-05.2005
Spatiotemporal receptive field organization in the lateral geniculate nucleus of cats and kittens, Journal of Neurophysiology, vol.78, issue.2, pp.1045-1061, 1997. ,
Do We Know What the Early Visual System Does?, Journal of Neuroscience, vol.25, issue.46, pp.25-10577, 2005. ,
DOI : 10.1523/JNEUROSCI.3726-05.2005
A simple white noise analysis of neuronal light responses, Network: Computation in Neural Systems, vol.12, issue.2, pp.199-213, 2001. ,
DOI : 10.1080/713663221
Functional asymmetries in ON and OFF ganglion cells of primate retina, Journal of Neuroscience, vol.22, issue.7, pp.2737-2747, 2002. ,
Differential expression of voltage-gated K+ and Ca2+ currents in bipolar cells in the zebrafish retinal slice, European Journal of Neuroscience, vol.32, issue.4, pp.1350-1362, 1998. ,
DOI : 10.1113/jphysiol.1978.sp012394
Receptive fields of P and M ganglion cells across the primate retina, Vision Research, vol.35, issue.1, pp.7-24, 1995. ,
DOI : 10.1016/0042-6989(94)E0066-T
Center surround receptive field structure of cone bipolar cells in primate retina, Vision Research, vol.40, issue.14, pp.1801-1811, 2000. ,
DOI : 10.1016/S0042-6989(00)00039-0
Dendritic field size and morphology of midget and parasol ganglion cells of the human retina., Proceedings of the National Academy of Sciences, pp.9666-9670, 1992. ,
DOI : 10.1073/pnas.89.20.9666
SpikeNET: A simulator for modeling large networks of integrate and fire neurons, Neurocomputing, vol.26, issue.27, pp.989-996, 1999. ,
DOI : 10.1016/S0925-2312(99)00095-8
Bipolar cells contribute to nonlinear spatial summation in the brisk-transient (Y) ganglion cell in mammalian retina, Journal of Neuroscience, vol.21, issue.19, pp.7447-7454, 2001. ,
Spike Generator Limits Efficiency of Information Transfer in a Retinal Ganglion Cell, Journal of Neuroscience, vol.24, issue.12, pp.2914-2922, 2004. ,
DOI : 10.1523/JNEUROSCI.5346-03.2004
The receptive-field spatial structure of cat retinal Y cells., The Journal of Physiology, vol.384, issue.1, pp.49-79, 1987. ,
DOI : 10.1113/jphysiol.1987.sp016443
The contrast sensitivity of retinal ganglion cells of the cat, The Journal of Physiology, vol.187, issue.3, pp.517-552, 1966. ,
DOI : 10.1113/jphysiol.1966.sp008107
Spatio-temporal interactions in cat retinal ganglion cells showing linear spatial summation., The Journal of Physiology, vol.341, issue.1, pp.279-307, 1983. ,
DOI : 10.1113/jphysiol.1983.sp014806
http://scat-he-g4, 2004. ,
Light-evoked responses of bipolar cells in a mammalian retina, Journal of Neurophysiology, vol.83, issue.4, pp.1817-1829, 2000. ,
Synaptic currents generating the inhibitory surround of ganglion cells in the mammalian retina, Journal of Neuroscience, vol.21, issue.13, pp.4852-4863, 2001. ,
A phenomenological model of visually evoked spike trains in cat geniculate nonlagged X-cells, Visual Neuroscience, vol.15, issue.6, pp.1157-1174, 1998. ,
DOI : 10.1017/S0952523898156158
Rapid Neural Coding in the Retina with Relative Spike Latencies, Science, vol.29, issue.3, pp.1108-1111, 2008. ,
DOI : 10.1016/S0896-6273(01)00251-3
Digital image processing, 1992. ,
Response variability of single cells in the dorsal lateral geniculate nucleus of the cat. Comparison with retinal input and effect of brain stem stimulation, Journal of Neurophysiology, vol.72, issue.3, pp.1278-1289, 1994. ,
The influence of different retinal subcircuits on the nonlinearity of ganglion cell behavior, Journal of Neuroscience, vol.22, issue.19, pp.8726-8738, 2002. ,
A model of colour processing in the retina of vertebrates: From photoreceptors to colour opposition and colour constancy phenomena, Neurocomputing, vol.12, issue.2-3, pp.113-129, 1996. ,
DOI : 10.1016/0925-2312(95)00114-X
Modeling Visual Perception for Image Processing, Computational and ambient intelligence : 9th international work-conference on artificial neural networks, pp.662-675, 2007. ,
DOI : 10.1007/978-3-540-73007-1_80
Linear and nonlinear spatial subunits in Y cat retinal ganglion cells., The Journal of Physiology, vol.262, issue.2, pp.265-284, 1976. ,
DOI : 10.1113/jphysiol.1976.sp011595
Spatiotemporal patterns at the retinal output, Journal of Neurophysiology, vol.80, issue.1, pp.447-451, 1998. ,
The dynamics of primate retinal ganglion cells, Progress in Brain Research, vol.134, pp.1-18, 2001. ,
Low Response Variability in Simultaneously Recorded Retinal, Thalamic, and Cortical Neurons, Neuron, vol.27, issue.3, pp.635-646, 2000. ,
DOI : 10.1016/S0896-6273(00)00072-6
Predicting Every Spike, Neuron, vol.30, issue.3, pp.803-817, 2001. ,
DOI : 10.1016/S0896-6273(01)00322-1
URL : https://doi.org/10.1016/s0896-6273(01)00322-1
Gap junctions with amacrine cells provide a feedback pathway for ganglion cells within the retina, Proceedings of the Royal Society B: Biological Sciences, vol.265, issue.1399, pp.919-925, 1399. ,
DOI : 10.1098/rspb.1998.0379
Correlated Firing Improves Stimulus Discrimination in a Retinal Model, Neural Computation, vol.17, issue.11, pp.2261-2291, 2004. ,
DOI : 10.1152/jn.01106.2002
Temporal contrast adaptation in the input and output signals of salamander retinal ganglion cells, Journal of Neuroscience, vol.21, issue.1, pp.287-299, 2001. ,
Slow Na+ inactivation and variance adaptation in salamander retinal ganglion cells, Journal of Neuroscience, vol.23, issue.4, pp.1506-1516, 2003. ,
Webvision: The organization of the retina and visual system, 2001. ,
Discharge patterns and functional organization of mammalian retina, Journal of Neurophysiology, vol.16, pp.37-68, 1953. ,
Spatial properties of horizontal cell responses in the turtle retina., The Journal of Physiology, vol.263, issue.2, pp.239-55, 1976. ,
DOI : 10.1113/jphysiol.1976.sp011630
Encoding of Natural Scene Movies by Tonic and Burst Spikes in the Lateral Geniculate Nucleus, Journal of Neuroscience, vol.24, issue.47, pp.10731-10740, 2004. ,
DOI : 10.1523/JNEUROSCI.3059-04.2004
On Contraction Analysis for Non-linear Systems, Automatica, vol.34, issue.6, pp.683-696, 1998. ,
DOI : 10.1016/S0005-1098(98)00019-3
Fine structure of parvocellular receptive fields in the primate fovea revealed by laser interferometry, Journal of Neuroscience, vol.20, issue.5, pp.2043-2053, 2000. ,
The Classical Receptive Field Surround of Primate Parasol Ganglion Cells Is Mediated Primarily by a Non-GABAergic Pathway, Journal of Neuroscience, vol.24, issue.15, pp.24-3736, 2004. ,
DOI : 10.1523/JNEUROSCI.5252-03.2004
The Silicon Retina, Scientific American, vol.264, issue.5, pp.76-82, 1991. ,
DOI : 10.1038/scientificamerican0591-76
Presynaptic Mechanism for Slow Contrast Adaptation in Mammalian Retinal Ganglion Cells, Neuron, vol.50, issue.3, pp.453-464, 2006. ,
DOI : 10.1016/j.neuron.2006.03.039
The intrinsic dynamics of retinal bipolar cells isolated
from tiger salamander, Visual Neuroscience, vol.15, issue.03, pp.425-438, 1998. ,
DOI : 10.1017/S0952523898153051
White-Noise Analysis of a Neuron Chain: An Application of the Wiener Theory, Science, vol.175, issue.4027, pp.175-1276, 1972. ,
DOI : 10.1126/science.175.4027.1276
The role of fixational eye movements in visual perception, Nature Reviews Neuroscience, vol.5, issue.3, pp.229-240, 2004. ,
DOI : 10.1038/nrn1348
The fundamental plan of the retina, Nature Neuroscience, vol.42, issue.9, pp.877-886, 2001. ,
DOI : 10.1038/82888
The generation and spread of S-potentials in fish (Cyprinidae), The Journal of Physiology, vol.192, issue.2, pp.437-61, 1967. ,
DOI : 10.1113/jphysiol.1967.sp008308
Regulation of the On bipolar cell mGluR6 pathway by Ca2+ Long-range synchronization of oscillatory light responses in the cat retina and lateral geniculate nucleus, Journal of Neuroscience Nature, vol.20, issue.44716567, pp.379-728, 1996. ,
The Light Response of Retinal Ganglion Cells Is Truncated by a Displaced Amacrine Circuit, Neuron, vol.18, issue.4, pp.637-650, 1997. ,
DOI : 10.1016/S0896-6273(00)80304-9
Intrinsic physiological properties of cat retinal ganglion cells, The Journal of Physiology, vol.258, issue.3, pp.787-802, 2002. ,
DOI : 10.1126/science.1470920
Turned on by Ca2+! The physiology and pathology of Ca2+-binding proteins in the retina, Trends in Neurosciences, vol.19, issue.12, pp.547-554, 1996. ,
DOI : 10.1016/S0166-2236(96)10059-X
Gap Junctions between Photoreceptor Cells in the Vertebrate Retina, Proceedings of the National Academy of Sciences, pp.1677-1681, 1973. ,
DOI : 10.1073/pnas.70.6.1677
Temporal contrast adaptation in salamander bipolar cells, Journal of Neuroscience, vol.21, issue.23, pp.9445-9454, 2001. ,
Vertical interactions across ten parallel, stacked representations in the mammalian retina, Nature, vol.410, issue.6828, pp.583-590, 2001. ,
DOI : 10.1038/35069068
Rate Coding Versus Temporal Order Coding: What the Retinal Ganglion Cells Tell the Visual Cortex, Neural Computation, vol.78, issue.6, pp.1255-1283, 2001. ,
DOI : 10.1016/0042-6989(96)00098-3
Visual transduction in cones of the monkey Macaca fascicularis., The Journal of Physiology, vol.427, issue.1, pp.681-713, 1990. ,
DOI : 10.1113/jphysiol.1990.sp018193
The effect of contrast on the transfer properties of cat retinal ganglion cells., The Journal of Physiology, vol.285, issue.1, pp.275-298, 1978. ,
DOI : 10.1113/jphysiol.1978.sp012571
underlies light adaptation in dogfish retinal ???on??? bipolar cells, The Journal of Physiology, vol.509, issue.66P., pp.343-350, 1999. ,
DOI : 10.1038/294592a0
Profound Contrast Adaptation Early in the Visual Pathway, Neuron, vol.42, issue.1, pp.155-162, 2004. ,
DOI : 10.1016/S0896-6273(04)00178-3
Performance of three recursive algorithms for fast space-variant Gaussian filtering, Real-Time Imaging, vol.9, issue.3, pp.215-228, 2003. ,
DOI : 10.1016/S1077-2014(03)00040-8
Light adaptation of primate cones: An analysis based on extracellular data, Vision Research, vol.23, issue.12, pp.1539-1547, 1983. ,
DOI : 10.1016/0042-6989(83)90167-0
The photocurrent response of human cones is fast and monophasic, BMC Neuroscience, vol.7, issue.1, pp.34-41, 2006. ,
DOI : 10.1186/1471-2202-7-34
Processing of natural temporal stimuli by macaque retinal ganglion cells, Journal of Neuroscience, issue.22, pp.22-9945, 2002. ,
The dynamics of the cat retinal X cell centre., The Journal of Physiology, vol.386, issue.1, pp.219-246, 1987. ,
DOI : 10.1113/jphysiol.1987.sp016531
Organization of the retina of the mudpuppy, Journal of Neurophysiology, vol.32, issue.3, pp.339-355, 1969. ,
Mathematical study of a neural gain control mechanism, 2007. ,
URL : https://hal.archives-ouvertes.fr/inria-00180730
Model and large-scale simulator of a biological retina with contrast gain control, 2008. ,
The vertebrate retina: A functional review, Research Report, vol.6532, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00280693
