New interface
Preprints, Working Papers, ...
Unbiasing Truncated Backpropagation Through Time
Abstract : Truncated Backpropagation Through Time (truncated BPTT) is a widespread method for learning recurrent computational graphs. Truncated BPTT keeps the computational benefits of Backpropagation Through Time (BPTT) while relieving the need for a complete backtrack through the whole data sequence at every step. However, truncation favors short-term dependencies: the gradient estimate of truncated BPTT is biased, so that it does not benefit from the convergence guarantees from stochastic gradient theory. We introduce Anticipated Reweighted Truncated Backpropagation (ARTBP), an algorithm that keeps the computational benefits of truncated BPTT, while providing unbiasedness. ARTBP works by using variable truncation lengths together with carefully chosen compensation factors in the backpropagation equation. We check the viability of ARTBP on two tasks. First, a simple synthetic task where careful balancing of temporal dependencies at different scales is needed: truncated BPTT displays unreliable performance, and in worst case scenarios, divergence, while ARTBP converges reliably. Second, on Penn Treebank character-level language modelling, ARTBP slightly outperforms truncated BPTT.
Document type :
Complete list of metadata
https://hal.inria.fr/hal-01660627
Contributor : Yann Ollivier Connect in order to contact the contributor
Submitted on : Monday, December 11, 2017 - 10:53:18 AM
Last modification on : Friday, November 18, 2022 - 9:25:32 AM
Links full text
Identifiers
  • HAL Id : hal-01660627, version 1
  • ARXIV : 1705.08209
Citation
Yann Ollivier, Corentin Tallec. Unbiasing Truncated Backpropagation Through Time. 2017. ⟨hal-01660627⟩
Share
Metrics
Record views
269
