Hierarchical Matrices: Algorithms and Analysis, 2015. ,
DOI : 10.1007/978-3-662-47324-5
Parallel black box $$\mathcal {H}$$ -LU preconditioning for elliptic boundary value problems, Computing and Visualization in Science, vol.40, issue.1, pp.4-6, 2008. ,
DOI : 10.1007/s00791-008-0098-9
Performance Of H-Lu Preconditioning For Sparse Matrices, Computational methods in applied mathematics, pp.336-349, 2008. ,
DOI : 10.2478/cmam-2008-0024
$${{\fancyscript{H}}} $$ H -LU factorization on many-core systems, Computing and Visualization in Science, vol.35, issue.2, pp.105-117, 2013. ,
DOI : 10.1145/1365490.1365500
Résolution directe rapide pour les éléments finis de frontière en électromagnétisme et acoustique : H-matrices. parallélisme et applications industrielles, Ph.D. dissertation, École Doctorale Galilée, 2014. ,
A fast block low-rank dense solver with applications to finite-element matrices, Journal of Computational Physics, vol.304, pp.170-188, 2016. ,
DOI : 10.1016/j.jcp.2015.10.012
A fast, memory efficient and robust sparse preconditioner based on a multifrontal approach with applications to finite-element matrices, International Journal for Numerical Methods in Engineering, vol.1, issue.4, pp.520-540, 2016. ,
DOI : 10.1002/nla.1680010405
An Efficient Solver for Sparse Linear Systems Based on Rank-Structured Cholesky Factorization, 1507. ,
Superfast Multifrontal Method for Large Structured Linear Systems of Equations, SIAM Journal on Matrix Analysis and Applications, vol.31, issue.3, pp.1382-1411, 2009. ,
DOI : 10.1137/09074543X
A Parallel Geometric Multifrontal Solver Using Hierarchically Semis-Separable Structure, ACM Trans. Math. Softw, vol.42, issue.3, p.21, 2016. ,
An Efficient Multicore Implementation of a Novel HSS-Structured Multifrontal Solver Using Randomized Sampling, SIAM Journal on Scientific Computing, vol.38, issue.5, pp.358-384, 2016. ,
DOI : 10.1137/15M1010117
A Robust Parallel Preconditioner for Indefinite Systems Using Hierarchical Matrices and Randomized Sampling, 2017 IEEE International Parallel and Distributed Processing Symposium (IPDPS), pp.897-906, 2017. ,
DOI : 10.1109/IPDPS.2017.21
Data-sparse Approximation by Adaptive H 2 -Matrices, Computing, vol.69, issue.1, pp.1-35, 2002. ,
DOI : 10.1007/s00607-002-1450-4
Fast Hierarchical Solvers For Sparse Matrices Using Extended Sparsification and Low-Rank Approximation, SIAM Journal on Scientific Computing, vol.39, issue.3, pp.797-830, 2017. ,
DOI : 10.1137/15M1046939
Sparse hierarchical solvers with guaranteed convergence, 2016. ,
Hierarchical Interpolative Factorization for Elliptic Operators: Differential Equations, Communications on Pure and Applied Mathematics, vol.34, issue.4, pp.1415-1451, 2016. ,
DOI : 10.1137/1034116
Compress and eliminate " solver for symmetric positive definite sparse matrices, 2016. ,
A Block Low-Rank Multithreaded Factorization for Dense BEM Operators, SIAM Conference on Parallel Processing for Scientific Computing (SIAM PP 2016), 2016. ,
Tile Low Rank Cholesky Factorization for Climate/Weather Modeling Applications on Manycore Architectures, pp.22-40, 2017. ,
DOI : 10.1007/s10766-016-0441-6
Improving Multifrontal Methods by Means of Block Low-Rank Representations, SIAM Journal on Scientific Computing, vol.37, issue.3, pp.1451-1474, 2015. ,
DOI : 10.1137/120903476
URL : https://hal.archives-ouvertes.fr/hal-00776859
Block low-rank multifrontal solvers: complexity, performance, and scalability, 2017. ,
PaStiX: a high-performance parallel direct solver for sparse symmetric positive definite systems, Parallel Computing, vol.28, issue.2, pp.301-321, 2002. ,
DOI : 10.1016/S0167-8191(01)00141-7
Sparse Supernodal Solver Using Block Low-Rank Compression, 2017 IEEE International Parallel and Distributed Processing Symposium Workshops (IPDPSW), 2017. ,
DOI : 10.1109/IPDPSW.2017.86
URL : https://hal.archives-ouvertes.fr/hal-01502215
Nested Dissection of a Regular Finite Element Mesh, SIAM Journal on Numerical Analysis, vol.10, issue.2, pp.345-363, 1973. ,
DOI : 10.1137/0710032
METIS: A software package for partitioning unstructured graphs, partitioning meshes, and computing fill-reducing orderings of sparse matrices, 1995. ,
Scotch and libScotch 5.1 User's Guide, user's manual, 127 pages Reordering Strategy for Blocking Optimization in Sparse Linear Solvers, SIAM Journal on Matrix Analysis and Applications, vol.38, issue.1, pp.226-248, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00410332
A Robust Criterion for the Modified Gram--Schmidt Algorithm with Selective Reorthogonalization, SIAM Journal on Scientific Computing, vol.25, issue.2, pp.417-441, 2003. ,
DOI : 10.1137/S106482750340783X
Scheduling and memory optimizations for sparse direct solver on multicore/multi-gpu cluster systems, 2015. ,
The university of Florida sparse matrix collection, ACM Transactions on Mathematical Software, vol.38, issue.1, pp.1-125, 2011. ,
DOI : 10.1145/2049662.2049663
Robust Memory-Aware Mappings for Parallel Multifrontal Factorizations, SIAM Journal on Scientific Computing, vol.38, issue.3, pp.256-279, 2016. ,
DOI : 10.1137/130938505
URL : https://hal.archives-ouvertes.fr/hal-00726644
Cache efficient bidiagonalization using BLAS 2.5 operators, ACM Transactions on Mathematical Software, vol.34, issue.3, pp.141-1433, 2008. ,
DOI : 10.1145/1356052.1356055
On the Complexity of the Block Low-Rank Multifrontal Factorization, SIAM Journal on Scientific Computing, vol.39, issue.4, pp.1710-1740, 2017. ,
DOI : 10.1137/16M1077192
URL : https://hal.archives-ouvertes.fr/hal-01322230
A Separator Theorem for Planar Graphs, SIAM Journal on Applied Mathematics, vol.36, issue.2, pp.177-189, 1979. ,
DOI : 10.1137/0136016
Controlling the Memory Subscription of Distributed Applications with a Task-Based Runtime System, 2016 IEEE International Parallel and Distributed Processing Symposium Workshops (IPDPSW), 2016. ,
DOI : 10.1109/IPDPSW.2016.105
URL : https://hal.archives-ouvertes.fr/hal-01380126
