Convergence Results for the (1, ?)-SA-ES Using the Theory of ?-Irreducible Markov Chains, Theoretical Computer Science, vol.334, issue.1-3, pp.35-69, 2005. ,
Linear Convergence on Positively Homogeneous Functions of a Comparison Based Step-Size Adaptive Randomized Search: the (1 + 1) ES with Generalized One-Fifth Success Rule, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00877161
Linear Convergence of Comparison-Based Step-Size Adaptive Randomized Search via Stability of Markov Chains, SIAM Journal on Optimization, vol.26, issue.3, pp.1589-1624, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-00877160
Global Convergence of Evolution Strategies in Spherical Problems: Some Simple Proofs and Difficulties, Theoretical Computer Science, vol.306, issue.1-3, pp.269-289, 2003. ,
Global Minimization Using an Augmented Lagrangian Method with Variable Lower-Level Constraints, Mathematical Programming, vol.125, issue.1, pp.139-162, 2010. ,
Verifiable Conditions for Irreducibility, Aperiodicity and T-chain Property of a General Markov Chain. Accepted for publication in Bernoulli, 2015. ,
A Globally Convergent Augmented Lagrangian Algorithm for Optimization with General Constraints and Simple Bounds, SIAM Journal on Numerical Analysis, vol.28, issue.2, pp.545-572, 1991. ,
A Genetic Algorithm Based Augmented Lagrangian Method for Constrained Optimization, Computational Optimization and Applications, vol.53, issue.3, pp.869-902, 2012. ,
The CMA Evolution Strategy: A Tutorial, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01297037
Completely Derandomized Self-Adaptation in Evolution Strategies, Evolutionary Computation, vol.9, issue.2, pp.159-195, 2001. ,
Multiplier and Gradient Methods, Journal of Optimization Theory and Applications, vol.4, issue.5, pp.303-320, 1969. ,
A Globally Convergent Augmented Lagrangian Pattern Search Algorithm for Optimization with General Constraints and Simple Bounds, SIAM Journal on Optimization, vol.12, issue.4, pp.1075-1089, 2002. ,
Markov Chains and Stochastic Stability, 1993. ,
Numerical Optimization, 2006. ,
A Method for Nonlinear Constraints in Minimization Problems, pp.283-298, 1969. ,
Coevolutionary Augmented Lagrangian Methods for Constrained Optimization, IEE Transactions on Evolutionary Computation, vol.4, issue.2, pp.114-124, 2000. ,
, It follows that Dh xopt,?opt,? (x opt + ?x, ? opt + ??) = h(x opt + ?x, ? opt + ??, ?) ? f (x opt ) = ? 2 h(x opt + x, ? opt + ?, ?) + (1 ? ? 2 )f (x opt ) ? f (x opt ) = ? 2, The constraints being active at x opt , h(x opt , ? opt , ?) = f (x opt )
, = ? 2 Dh xopt,?opt,? (x opt + x, ? opt + ?)
