Surface reconstruction by voronoi filtering, Discrete & Computational Geometry, vol.22, issue.4, pp.481-504, 1999. ,
Fabricating articulated characters from skinned meshes Design and Fabrication of Materials with Desired Deformation Behavior, Proceedings of Siggraph 2010), pp.1-47, 2010. ,
Pushing the Limits of 3D Color Printing, ACM Transactions on Graphics, vol.35, issue.1, pp.1-4, 2015. ,
DOI : 10.1145/1201775.882289
Dapper: Decompose-and-pack for 3d printing, ACM Trans. Graph, vol.34, issue.213, pp.1-21312, 2015. ,
Multiobjective optimization of part building orientation in stereolithography, Rapid Prototyping Journal, vol.1, issue.4, pp.12-23, 1995. ,
Specifying nonuniform cusp heights as a potential aid for adaptive slicing, Rapid Prototyping Journal, vol.6, issue.3, pp.204-212, 2000. ,
Computational design of mechanical characters Determination of optimal build direction for different rapid prototyping applications, Proceedings of the 14th European Forum on Rapid Prototyping, pp.1-83, 2009. ,
Computers and Intractability: A Guide to the Theory of NP-Completeness, 1979. ,
A new adaptive slicing approach for the fully dense freeform fabrication (fdff) process, Journal of Intelligent Manufacturing, vol.24, issue.4, pp.683-694, 2013. ,
Clean color: Improving multifilament 3d prints, Computer Graphics Forum, vol.33, issue.2, pp.469-478, 2014. ,
Orthogonal slicing for additive manufacturing, Computers & Graphics, vol.37, issue.6, pp.669-675, 2013. ,
Adaptive slicing with sloping layer surfaces, Rapid Prototyping Journal, vol.3, issue.3, pp.89-98, 1997. ,
Approximate pyramidal shape decomposition, ACM Trans. Graph, vol.33, issue.213, pp.1-21312, 2014. ,
Intersection-free and topologically faithful slicing of implicit solid, Journal of Computing and Information Science in Engineering, vol.13, issue.2, p.21009, 2013. ,
Best piecewise constant approximation of a function of single variable, Operations Research Letters, vol.7, issue.4, pp.205-210, 1988. ,
Creating works-like prototypes of mechanical objects, ACM Trans. Graph, vol.33, issue.217, pp.1-217, 2014. ,
An accurate slicing procedure for layered manufacturing, Computer-Aided Design, vol.28, issue.9, pp.683-697, 1996. ,
Mesh saliency, ACM Trans. Graph, vol.24, issue.3, pp.659-666, 2005. ,
Chopper: Partitioning Models into 3D-printable Parts, Proceedings of Siggraph Asia 2012), pp.1-129, 2012. ,
Region-based adaptive slicing, Computer-Aided Design, vol.31, issue.5, pp.317-333, 1999. ,
Part build orientations based on volumetric error in fused deposition modelling, The International Journal of Advanced Manufacturing Technology, vol.16, issue.3, pp.162-168, 2000. ,
Real time adaptive slicing for fused deposition modelling, International Journal of Machine Tools and Manufacture, vol.43, issue.1, pp.61-71, 2003. ,
Slicing procedures in layered manufacturing: a review, pp.274-288, 2003. ,
Dual-color mixing for fused deposition modeling printers, Computer Graphics Forum, vol.33, issue.2, pp.479-486, 2014. ,
Adaptive slicing using stepwise uniform refinement, Rapid Prototyping Journal, vol.2, issue.4, pp.20-26, 1996. ,
DOI : 10.1109/38.469518
Accurate exterior, fast interior layered manufacturing, Rapid Prototyping Journal, vol.3, issue.2, pp.44-52, 1997. ,
DOI : 10.1108/13552549610153370
Branching support structures for 3d printing, ACM SIGGRAPH 2014 Studio. SIGGRAPH '14, pp.1-9, 2014. ,
High-contrast computational caustic design, Proc. SIGGRAPH 2014, pp.1-7411, 2014. ,
Adaptive slicing for sls prototyping, Computer-Aided Design and Applications, vol.5, pp.1-4, 2008. ,
Computational design of actuated deformable characters, Proceedings of Siggraph 2013), pp.1-8210, 2013. ,
Cofifab: Coarse-to-fine fabrication of large 3d objects, ACM Trans. Graph, vol.35, issue.45, pp.1-4511, 2016. ,
Efficient slicing for layered manufacturing, Rapid Prototyping Journal, vol.4, issue.4, pp.151-167, 1998. ,
Optimum part deposition orientation in fused deposition modeling, International Journal of Machine Tools and Manufacture, vol.44, issue.6, pp.585-594, 2004. ,
Local adaptive slicing, Rapid Prototyping Journal, vol.4, issue.3, pp.118-127, 1998. ,
Fdm systems and local adaptive slicing, Materials & design, vol.20, issue.2, pp.77-82, 1999. ,
Cross-sectional Structural Analysis for 3D Printing Optimization, SIGGRAPH Asia 2013 Technical Briefs. SA '13, pp.1-5, 2013. ,
Openfab: a programmable pipeline for multi-material fabrication, 2013. ,
Saliency-preserving slicing optimization for effective 3d printing, Computer Graphics Forum, vol.34, issue.6, pp.148-160, 2015. ,
Improved surface quality in 3d printing by optimizing the printing direction, Computer Graphics Forum, vol.35, issue.2, pp.59-70, 2016. ,
Optimal orientation with variable slicing in stereolithography, Rapid Prototyping Journal, vol.3, issue.3, pp.76-88, 1997. ,
Perceptual models of preference in 3d printing direction, ACM Trans. Graph, vol.34, issue.215, pp.1-21512, 2015. ,
Adaptive direct slicing of the solid model for rapid prototyping, International Journal of Production Research, vol.38, issue.1, pp.69-83, 2000. ,
