3D-printed miniature gas cell for photoacoustic spectroscopy of trace gases, Optics Letters, vol.39, issue.16, pp.4796-4799, 2014. ,
DOI : 10.1364/OL.39.004796
A comparison between Kriging and radial basis function networks for nonlinear prediction, Nonlinear Signal and Image Processing, pp.726-730, 1999. ,
ooDACE toolbox: a flexible object-oriented kriging implementation, The Journal of Machine Learning Research, vol.15, issue.1, pp.3183-3186, 2014. ,
Bayesian Prediction of Deterministic Functions, with Applications to the Design and Analysis of Computer Experiments, Journal of the American Statistical Association, vol.15, issue.416, p.953, 1991. ,
DOI : 10.1093/biomet/64.2.309
Multi-fidelity information fusion based on prediction of kriging, Structural and Multidisciplinary Optimization, vol.54, issue.2???3, pp.1267-1280, 2015. ,
DOI : 10.1016/S0951-8320(96)00078-6
Numerical Procedures for Surface Fitting of Scattered Data by Radial Functions, SIAM Journal on Scientific and Statistical Computing, vol.7, issue.2, pp.639-659, 1986. ,
DOI : 10.1137/0907043
Multi-fidelity optimization via surrogate modelling, Proceedings of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.463, issue.2088, pp.3251-3269, 1900. ,
DOI : 10.1098/rspa.2007.1900
Engineering design via surrogate modelling a practical guide Challenges in the design and fabrication of a lab-on-a-chip photoacoustic gas sensor, Sensors, vol.143390, issue.1, pp.957-974, 2008. ,
A radial basis function method for global optimization Evaluating the CMA evolution strategy on multimodal test functions, Parallel Problem Solving from Nature PPSN VIII, pp.282-291, 2001. ,
Development of a MEMS-Scale Photoacoustic Chemical Sensor Using a Quantum Cascade Laser, IEEE Sensors Journal, vol.10, issue.3, pp.572-577, 2009. ,
DOI : 10.1109/JSEN.2009.2038665
Rational radial basis function interpolation with applications to antenna design, Journal of Computational and Applied Mathematics, vol.233, issue.4, pp.889-904, 2009. ,
DOI : 10.1016/j.cam.2009.08.058
Comparative studies of metamodelling techniques under multiple modelling criteria, Structural and Multidisciplinary Optimization, vol.23, issue.1, pp.1-13, 2001. ,
DOI : 10.1007/s00158-001-0160-4
Efficient global optimization of expensive black-box functions, Journal of Global Optimization, vol.13, issue.4, pp.455-492, 1998. ,
DOI : 10.1023/A:1008306431147
Predicting the output from a complex computer code when fast approximations are available, Biometrika, vol.87, issue.1, pp.1-13, 2000. ,
DOI : 10.1093/biomet/87.1.1
The Physics of Signal Generation and Detection, Optoacoustic Spectroscopy and Detection, pp.1-25, 1977. ,
DOI : 10.1016/B978-0-12-544150-6.50006-4
A statistical approach to some basic mine valuation problems on the witwatersrand, Journal of the Chemical, Metallurgical and Mining Society of South Africa, vol.52, issue.6, pp.119-139, 1951. ,
Cokriging-Based Sequential Design Strategies Using Fast Cross-Validation Techniques for Multi-Fidelity Computer Codes, Technometrics, vol.28, issue.3, pp.418-427, 2015. ,
DOI : 10.1080/00401706.2012.723572
Comparison of Adaptive Sampling Methods for Generation of Surrogate Aerodynamic Models, AIAA Journal, vol.38, issue.157, pp.797-808, 2013. ,
DOI : 10.1016/S0898-1221(01)00299-1
Interpolation of scattered data: Distance matrices and conditionally positive definite functions, Constructive Approximation, vol.23, issue.1, pp.11-221937, 1986. ,
DOI : 10.1007/978-3-0348-7189-1_25
Bayesian Design and Analysis of Computer Experiments: Use of Derivatives in Surface Prediction, Technometrics, vol.15, issue.3, pp.243-255, 1993. ,
DOI : 10.1214/aos/1176350247
Radial basis functions for multivariable interpolation: a review Algorithms for Approximation, pp.143-167, 1987. ,
Radial basis function methods for interpolation to functions of many variables, pp.2-24, 2001. ,
Improved Strategies for Radial basis Function Methods for Global Optimization, Journal of Global Optimization, vol.90, issue.1, pp.113-135, 2006. ,
DOI : 10.1007/978-3-0348-8696-3_14
An algorithm for selecting a good value for the parameter c in radial basis function interpolation, Advances in Computational Mathematics, vol.11, issue.2/3, pp.193-210, 1999. ,
DOI : 10.1023/A:1018975909870
Glì ere A (2016) Miniaturized differential Helmholtz resonators for photoacoustic trace gas detection, Sensors and Actuators B ,
The Design and Analysis of Computer Experiments Global optimization with nonparametric function fitting, Proceedings of the ASA, Section on Physical and Engineering Sciences pp, pp.183-186, 1996. ,
A two-stage multi-fidelity optimization procedure for honeycomb-type cellular materials, Computational Materials Science, vol.49, issue.3, pp.500-511, 2010. ,
DOI : 10.1016/j.commatsci.2010.05.041
Multi-fidelity design of stiffened composite panel with a crack, Structural and Multidisciplinary Optimization, vol.23, issue.5, pp.347-356, 2002. ,
DOI : 10.1007/s00158-002-0195-1
Review of Metamodeling Techniques in Support of Engineering Design Optimization, Journal of Mechanical Design, vol.26, issue.28, pp.370-380, 2007. ,
DOI : 10.1023/A:1023283917997
Sequential Design and Analysis of High-Accuracy and Low-Accuracy Computer Codes, Technometrics, vol.34, issue.1, pp.37-46, 2013. ,
DOI : 10.2307/1269548
Design and characteristics of a differential Helmholtz resonant photoacoustic cell for infrared gas detection, Infrared Physics & Technology, vol.40, issue.1, pp.1-23, 1999. ,
DOI : 10.1016/S1350-4495(98)00038-3
