Approximating the Spectrum of a Graph - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
The spectrum of a network or graph $G=(V,E)$ with adjacency matrix $A$, consists of the eigenvalues of the normalized Laplacian $L= I - D^{-1/2} A D^{-1/2}$. This set of eigenvalues encapsulates many aspects of the structure of the graph, including the extent to which the graph posses community structures at multiple scales. We study the problem of approximating the spectrum $\lambda = (\lambda_1,\dots,\lambda_{|V|})$, $0 \le \lambda_1,\le \dots, \le \lambda_{|V|}\le 2$ of $G$ in the regime where the graph is too large to explicitly calculate the spectrum. We present a sublinear time algorithm that, given the ability to query a random node in the graph and select a random neighbor of a given node, computes a succinct representation of an approximation $\widetilde \lambda = (\widetilde \lambda_1,\dots,\widetilde \lambda_{|V|})$, $0 \le \widetilde \lambda_1,\le \dots, \le \widetilde \lambda_{|V|}\le 2$ such that $\|\widetilde \lambda - \lambda\|_1 \le \epsilon |V|$. Our algorithm has query complexity and running time $exp(O(1/\epsilon))$, independent of the size of the graph, $|V|$. We demonstrate the practical viability of our algorithm on 15 different real-world graphs from the Stanford Large Network Dataset Collection, including social networks, academic collaboration graphs, and road networks. For the smallest of these graphs, we are able to validate the accuracy of our algorithm by explicitly calculating the true spectrum; for the larger graphs, such a calculation is computationally prohibitive. In addition we study the implications of our algorithm to property testing in the bounded degree graph model.
hal-01661199 , version 1 (11-12-2017)
David Cohen-Steiner, Weihao Kong, Christian Sohler, Gregory Valiant. Approximating the Spectrum of a Graph. KDD 2018 - Proceedings of the 24th ACM SIGKDD International Conference on Knowledge Discovery & Data Mining, Aug 2018, London, United Kingdom. ⟨hal-01661199⟩
211 Consultations
0 Téléchargements
