2017: Observations 436 for reanalysis, Bull. Amer. Met. Soc ,
2011: The Twentieth Century Reanalysis Project. Q, J. R. Meteorol, p.445 ,
2011: The ERA-Interim reanalysis: 452 configuration and performance of the data assimilation system, Q. J. R. Meteorol. Soc, vol.451, issue.137, pp.453-553 ,
Uncertainties of sea surface and air temperature in the 461 CERA-20C coupled reanalysis ensemble. Q, J. R. Meteorol. Soc, 2017. ,
2012: Detecting inhomogeneities in the Twentieth Century 463 ,
2017: The potential value of early (1939-1967) upper-air data in 467 atmospheric climate reanalysis, Quart. J. Roy. Meteorol. Soc, vol.143, pp.1185-1196 ,
The NCEP/NCAR 40-year reanalysis project, Bull. Amer. Meteorol. Soc, vol.472, issue.77, pp.437-473, 1996. ,
A coupled data 475 assimilation system for climate reanalysis, Quarterly Journal of the Royal Meteorological, vol.476, 2016. ,
CERA-20C: An Earth system 478 approach to climate reanalysis, ECMWF Newsletter, vol.2017, issue.150, pp.25-30 ,
Towards consistent diagnostics 480 of the coupled atmosphere and ocean energy budgets, J. Climate, vol.2017 ,
Toward variational data assimilation for coupled 486 models: first experiments on a diffusion problem, p.487, 2016. ,
Comparing 493 reanalysis-based volume and temperature transports through Arctic Gateways with mooring- 494 derived estimates, J. Geophys. Res. Oceans, 2017. ,
2017: Recent Advances in Satellite Data Rescue, p.501 ,
ERA-20C: An Atmospheric Reanalysis of the Twentieth Century, J. Climate, vol.504, issue.29, pp.505-4083, 2016. ,
MERRA ? NASA's Modern-Era Retrospective Analysis for Research 511 and Applications, J. Climate, vol.510, issue.24, pp.3624-3648, 2011. ,
An Assimilated Dataset for Earth Science Applications, Bulletin of the American Meteorological Society, vol.74, issue.12, pp.2331-2342, 1993. ,
DOI : 10.1175/1520-0477(1993)074<2331:AADFES>2.0.CO;2
2017: Strongly coupled data assimilation 531 experiments with linearized ocean-atmosphere balance relationships, Mon. Wea. Rev, vol.532 ,
The Met Office Hadley Centre sea ice and sea 534 surface temperature data set, version 2: 1. Sea ice concentrations, Journal of Geophysical, vol.535, 2014. ,
Correlation operators based on an 545 implicitly formulated diffusion equation solved with the Chebyshev iteration, Q. J. Roy, p.546, 2016. ,
a) Africa, b) India/Monsoon region, c) South America,. Time 621 interval considered: 1901-2000 on 1° spatial resolution, monthly temporal resolution ,
