CLOSE: A Costless Service Offloading Strategy for Distributed Edge Cloud - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
New bandwidth-intensive and time-constrained services in 5G networks combined with network function virtual-ization is pushing network operators to deploy distributed cloud infrastructures at the edge of the network. Allocating resources in capacity-limited infrastructures raises new challenges, which have not really been so far considered in the cloud literature. In this context, we investigate placement and offloading strategies of constrained services. We set design principles of future distributed edge clouds in order to meet application requirements. We precisely introduce a costless distributed resource allocation algorithm, named CLOSE, which considers local information only. We compare via simulations the performance of CLOSE against those obtained by using mechanisms proposed in the literature, notably the Tricircle project within OpenStack. It turns out that the proposed distributed algorithm yields better performance while requiring less overhead.
close-costless-service.pdf (573.19 Ko) Télécharger le fichier
hal-01661624 , version 1 (12-12-2017)
  • HAL Id : hal-01661624 , version 1
Farah Slim, Fabrice Guillemin, Yassine Hadjadj-Aoul. CLOSE: A Costless Service Offloading Strategy for Distributed Edge Cloud. GTCC 2018 - IEEE Workshop on Game Theory in Computer Communications, Jan 2018, Las Vegas, United States. pp.1-6. ⟨hal-01661624⟩
581 Consultations
189 Téléchargements
