Complexity issues in coding theory, Electronic Colloquium on Computational Complexity, 1997. ,
Decoding Random Binary Linear Codes in 2 n/20: How 1???+???1???=???0 Improves Information Set Decoding, Advances in Cryptology -EUROCRYPT 2012, Lecture Notes in Comput. Sci, 2012. ,
DOI : 10.1007/978-3-642-29011-4_31
On minimum distance decoding of linear codes, Proc. 5th Joint Soviet-Swedish Int. Workshop Inform. Theory, pp.50-52, 1991. ,
Modeling Bit Flipping Decoding Based on Nonorthogonal Check Sums With Application to Iterative Decoding Attack of McEliece Cryptosystem, IEEE Transactions on Information Theory, vol.53, issue.1, pp.402-411, 2007. ,
DOI : 10.1109/TIT.2006.887515
Strong asymptotics for Krawtchouk polynomials, Journal of Computational and Applied Mathematics, vol.100, issue.2, pp.121-144, 1998. ,
DOI : 10.1016/S0377-0427(98)00183-6
URL : https://doi.org/10.1016/s0377-0427(98)00183-6
A Statistical Decoding Algorithm for General Linear Block Codes, Proceedings of the 8 th IMA International Conference, pp.1-8, 2001. ,
DOI : 10.1007/3-540-45325-3_1
Decoding Random Linear Codes in $\tilde{\mathcal{O}}(2^{0.054n})$, Advances in Cryptology -ASIACRYPT 2011, pp.107-124, 2011. ,
DOI : 10.1007/978-3-642-25385-0_6
On Computing Nearest Neighbors with Applications to Decoding of Binary Linear Codes, Advances in Cryptology -EUROCRYPT 2015, pp.203-228, 2015. ,
DOI : 10.1007/978-3-662-46800-5_9
Statistical Decoding Revisited, ACISP Lecture Notes in Comput. Sci, vol.4058, pp.283-294, 2006. ,
DOI : 10.1007/11780656_24
The use of information sets in decoding cyclic codes, IEEE Transactions on Information Theory, vol.8, issue.5, pp.5-9, 1962. ,
DOI : 10.1109/TIT.1962.1057777
A method for finding codewords of small weight, Coding Theory and Applications, pp.106-113, 1988. ,
DOI : 10.1007/BFb0019850
