Polynomial Time Attack on Wild McEliece Over Quadratic Extensions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Information Theory Année : 2017
We present a polynomial-time structural attack against the McEliece system based on Wild Goppa codes defined over a quadratic finite field extension. We show that such codes can be efficiently distinguished from random codes. The attack uses this property to compute a filtration, that is to say, a family of nested subcodes which will reveal their secret algebraic description.
article.pdf (528.17 Ko) Télécharger le fichier
hal-01661935 , version 1 (12-12-2017)
Alain Couvreur, Ayoub Otmani, Jean-Pierre Tillich. Polynomial Time Attack on Wild McEliece Over Quadratic Extensions. IEEE Transactions on Information Theory, 2017, 63 (1), pp.404--427. ⟨10.1109/TIT.2016.2574841⟩. ⟨hal-01661935⟩
567 Consultations
182 Téléchargements
