A. Bennatan and D. Burshtein, Design and analysis of nonbinary LDPC codes for arbitrary discrete-memoryless channels, IEEE Transactions on Information Theory, vol.52, issue.2, pp.549-583, 2006.
DOI : 10.1109/TIT.2005.862080
I. Dumer, Soft-decision decoding of Reed-Muller codes: a simplified algorithm, IEEE Transactions on Information Theory, vol.52, issue.3, pp.954-963, 2006.
DOI : 10.1109/TIT.2005.864425
R. Koetter and A. Vardy, Algebraic soft-decision decoding of reed-solomon codes, IEEE Transactions on Information Theory, vol.49, issue.11, pp.2809-2825, 2003.
DOI : 10.1109/TIT.2003.819332
R. Koetter and A. Vardy, Algebraic soft-decision decoding of reed-solomon codes, IEEE Transactions on Information Theory, vol.49, issue.11, 2003.
I. Márquez-corbella and J. Tillich, Using Reed-Solomon codes in the (u|u+v) construction and an application to cryptography, Proc. IEEE Int. Symposium Inf. Theory -ISIT, pp.930-934, 2016.
I. Márquez-corbella, J. Tillich, E. Sa¸so?sa¸so?-glu, E. Telatar, and E. Ar?kan, Attaining capacity with algebraic geometry codes through the (U |U + V ) construction and Koetter-Vardy soft decoding. preprint, arXiv:1701.07112 Polarization for arbitrary discrete memoryless channels, Sa¸so?gluSa¸so?Sa¸so?glu. Polarization and polar codes. Foundations and Trends in Communications and Information Theory Proc. IEEE Inf, pp.259-381, 2009.
M. A. Tsfasman, S. Vl?, and T. Zink, Modular curves, Shimura curves, and Goppa codes, better than Varshamov-Gilbert bound, Mathematische Nachrichten, vol.65, issue.1, pp.21-28, 1982.
DOI : 10.1090/pspum/033.2/546621
