Quality Gain Analysis of the Weighted Recombination Evolution Strategy on General Convex Quadratic Functions, Proceedings of the 14th ACM/SIGEVO Conference on Foundations of Genetic Algorithms, FOGA '17, pp.111-126, 2017. ,
DOI : 10.1007/11844297_3
URL : https://hal.archives-ouvertes.fr/hal-01516326
Evaluating the CMA Evolution Strategy on Multimodal Test Functions, pp.282-291, 2004. ,
DOI : 10.1007/978-3-540-30217-9_29
Principled Design of Continuous Stochastic Search: From Theory to Practice, Theory and Principled Methods for the Design of Metaheuristics, 2014. ,
DOI : 10.1007/978-3-642-33206-7_8
URL : https://hal.archives-ouvertes.fr/hal-00808450
Optimal Weighted Recombination, Foundations of Genetic Algorithms -FOGA VIII, pp.215-237, 2005. ,
DOI : 10.1007/11513575_12
URL : http://users.cs.dal.ca/~dirk/docs/FOGA05.pdf
A Method for Handling Uncertainty in Evolutionary Optimization With an Application to Feedback Control of Combustion, IEEE Transactions on Evolutionary Computation, vol.13, issue.1, pp.180-197, 2009. ,
DOI : 10.1109/TEVC.2008.924423
URL : https://hal.archives-ouvertes.fr/inria-00276216
Benchmarking the novel CMA-ES restart strategy using the search history on the BBOB noiseless testbed, Proceedings of the Genetic and Evolutionary Computation Conference Companion on , GECCO '17, pp.1780-1787, 2017. ,
DOI : 10.1145/1570256.1570333
Online Model Selection for Restricted Covariance Matrix Adaptation, Nature -PPSN XIV, vol.9, issue.2, pp.3-13, 2016. ,
DOI : 10.1007/978-3-540-87700-4_30
URL : https://hal.archives-ouvertes.fr/hal-01333840
Evolutionsstrategie '94, Frommann-Holzboog, 1994. ,
Towards a theory of 'evolution strategies': Results for (1+, ?)-strategies on (nearly) arbitrary fitness functions, in: Parallel Problem Solving from, Nature -PPSN III, pp.58-67, 1994. ,
The Theory of Evolution Strategies, Natural Computing Series, 2001. ,
DOI : 10.1007/978-3-662-04378-3
Convergence results for the <mml:math altimg="si1.gif" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd"><mml:mo stretchy="false">(</mml:mo><mml:mn>1</mml:mn><mml:mo>,</mml:mo><mml:mi>??</mml:mi><mml:mo stretchy="false">)</mml:mo></mml:math>-SA-ES using the theory of <mml:math altimg="si2.gif" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd"><mml:mi>??</mml:mi></mml:math>-irreducible Markov chains, Theoretical Computer Science, vol.334, issue.1-3, pp.35-69, 2005. ,
DOI : 10.1016/j.tcs.2004.11.017
Reconsidering the progress rate theory for evolution strategies in finite dimensions, Proceedings of the 8th annual conference on Genetic and evolutionary computation , GECCO '06, pp.445-452, 2006. ,
DOI : 10.1145/1143997.1144081
Log-Linear Convergence and Optimal Bounds for the (1???+???1)-ES, pp.207-218, 2008. ,
DOI : 10.1007/978-3-540-79305-2_18
URL : https://hal.archives-ouvertes.fr/inria-00173483
Auger, Log-linear convergence of the scale-invariant (µ/µw, ?)-es and optimal µ for intermediate recombination for large population sizes, in: Parallel Problem Solving from, Nature - PPSN XI, pp.52-62, 2010. ,
Analysis of comparison-based stochastic continuous black-box optimization algorithms, Habilitation, 2015. ,
URL : https://hal.archives-ouvertes.fr/tel-01468781
A Simple Modification in CMA-ES Achieving Linear Time and Space Complexity, Nature -PPSN X, pp.296-305, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00270901
A computationally efficient limited memory CMA-ES for large scale optimization, Proceedings of the 2014 conference on Genetic and evolutionary computation, GECCO '14, pp.397-404, 2014. ,
DOI : 10.1145/2576768.2598294
URL : https://hal.archives-ouvertes.fr/hal-00981135
Projection-Based Restricted Covariance Matrix Adaptation for High Dimension, Proceedings of the 2016 on Genetic and Evolutionary Computation Conference, GECCO '16, pp.197-204, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01306551
On the use of evolution strategies for optimising certain positive definite quadratic forms, Proceedings of the 9th annual conference on Genetic and evolutionary computation , GECCO '07, pp.634-641, 2007. ,
DOI : 10.1145/1276958.1277094
How the (1+1) ES using isotropic mutations minimizes positive definite quadratic forms, Theoretical Computer Science, vol.361, issue.1, pp.38-56, 2006. ,
DOI : 10.1016/j.tcs.2006.04.004
Weighted recombination evolution strategy on a class of PDQF's, Proceedings of the tenth ACM SIGEVO workshop on Foundations of genetic algorithms, FOGA '09, pp.1-12, 2009. ,
DOI : 10.1145/1527125.1527127
The Dynamics of Self-Adaptive Multirecombinant Evolution Strategies on the General Ellipsoid Model, IEEE Transactions on Evolutionary Computation, vol.18, issue.5, pp.764-778, 2014. ,
DOI : 10.1109/TEVC.2013.2283968
The Dynamics of Cumulative Step Size Adaptation on the Ellipsoid Model, Evolutionary Computation, vol.4193, issue.1, pp.25-57, 2016. ,
DOI : 10.1007/978-3-0348-5927-1
Mirrored sampling in evolution strategies with weighted recombination, Proceedings of the 13th annual conference on Genetic and evolutionary computation, GECCO '11, pp.861-868, 2011. ,
DOI : 10.1145/2001576.2001694
URL : https://hal.archives-ouvertes.fr/inria-00612522
Auger, Log-linear convergence of the scale-invariant (µ/µw, ?)-ES and optimal mu for intermediate recombination for large population, 2010. ,
General Lower Bounds for Evolutionary Algorithms, pp.21-31, 2006. ,
URL : https://hal.archives-ouvertes.fr/inria-00112820
Non-Uniform Random Variate Generation, 1986. ,
DOI : 10.1007/978-1-4613-8643-8
But Inherit Small! On the Analysis of Rescaled Mutations in ( ? 1, ? ?)-ES with Noisy Fitness Data, in: Parallel Problem Solving from, Nature -PPSN V, pp.109-118, 1998. ,
Weighted multirecombination evolution strategies, Theoretical Computer Science, vol.361, issue.1, pp.18-37, 2006. ,
DOI : 10.1016/j.tcs.2006.04.003
Completely Derandomized Self-Adaptation in Evolution Strategies, Evolutionary Computation, vol.9, issue.2, pp.159-195, 2001. ,
DOI : 10.1016/0004-3702(95)00124-7
Asymptotic theory of statistics and probability, 2008. ,
A Remark on Stirling's Formula, The American Mathematical Monthly, vol.62, issue.1, pp.26-29, 1955. ,
DOI : 10.2307/2308012
Adaptive estimation of a quadratic functional of a density by model selection, ESAIM: Probability and Statistics, vol.28, pp.1302-1338, 2000. ,
DOI : 10.1214/aos/1015957395
