New interface
Book sections
Algorithm Selector and Prescheduler in the ICON challenge
François Gonard 1, 2 Marc Schoenauer 2 Michèle Sebag 2, 3
2 TAU - TAckling the Underspecified
LRI - Laboratoire de Recherche en Informatique, Inria Saclay - Ile de France
Abstract : Algorithm portfolios are known to offer robust performances, efficiently overcoming the weakness of every single algorithm on some particular problem instances. Two complementary approaches to get the best out of an algorithm portfolio is to achieve algorithm selection (AS), and to define a scheduler, sequentially launching a few algorithms on a limited computational budget each. The presented Algorithm Selector And Prescheduler system relies on the joint optimization of a pre-scheduler and a per instance AS, selecting an algorithm well-suited to the problem instance at hand. ASAP has been thoroughly evaluated against the state-of-the-art during the ICON challenge for algorithm selection, receiving an honourable mention. Its evaluation on several combinatorial optimization benchmarks exposes surprisingly good results of the simple heuristics used; some extensions thereof are presented and discussed in the paper.
Complete list of metadata
Cited literature [24 references]  Display  Hide  Download
https://hal.inria.fr/hal-01663174
Contributor : François Gonard Connect in order to contact the contributor
Submitted on : Wednesday, December 13, 2017 - 6:20:16 PM
Last modification on : Tuesday, October 25, 2022 - 4:20:39 PM
File
gonard_META_chapter_extended_c...
Identifiers
  • HAL Id : hal-01663174, version 1
Citation
François Gonard, Marc Schoenauer, Michèle Sebag. Algorithm Selector and Prescheduler in the ICON challenge. El-Ghazali Talbi; Amir Nakib. Bioinspired heuristic optimization , Springer Verlag, In press, Computational Intelligence. ⟨hal-01663174⟩
Share
Metrics
Record views
181
Files downloads
155
