Optical Networks: A Practical Perspective, 2009. ,
Sparse-partial wavelength conversion: Converter placement and wavelength assignment, Optical Switching and Networking, vol.7, issue.2, pp.66-74, 2010. ,
DOI : 10.1016/j.osn.2009.09.003
Optical burst switching (OBS)?a new paradigm for an Optical Internet, pp.69-84, 1999. ,
On optical burst switching and self-similar traffic, IEEE Communications Letters, vol.4, issue.3, pp.98-100, 2000. ,
DOI : 10.1109/4234.831037
Traffic Load Bounds for Optical Burst-Switched Networks with Dynamic Wavelength Allocation, pp.209-226, 2001. ,
DOI : 10.1007/978-0-387-35491-0_14
Study of traffic statistics of assembled burst traffic in optical burstswitched networks, ITCom 2002: The Convergence of Information Technologies and Communications , International Society for Optics and Photonics, pp.149-159, 2002. ,
Does burst assembly really reduce the self-similarity?, Journal of Lightwave Technology, pp.124-126, 2003. ,
DOI : 10.1109/OFC.2003.1247540
Performance analysis of an OBS edge router, Photonics Technology Letters, IEEE, vol.16, issue.2, pp.695-697, 2004. ,
Blocking probability evaluation of end-to-end dynamic WDM networks, Photonic Network Communications, vol.59, issue.3, p.560 ,
DOI : 10.1016/j.peva.2004.07.005
A proposal of dynamic RWA using ant colony in optical burst switched networks, The Eleventh International Conference on Networks, pp.246-252, 2012. ,
A novel grooming algorithm with the 565 ,
Join routing and dimensioning heuristic for dynamic WDM optical mesh networks with wavelength conversion, Optical Fiber Technology, vol.20, issue.3, pp.217-223, 2014. ,
DOI : 10.1016/j.yofte.2014.02.001
Situational analysis of significant research contribution in Optical 570 ,
Unavailability analysis of long-haul networks, Selected Areas in Communications, IEEE Journal on, vol.12, issue.1, pp.100-109, 1994. ,
Survivability of multiple fiber duct failures, Third International Workshop on the Design of Reliable Communication Networks, pp.7-10 ,
Design of logical topologies for wavelength-routed all-optical networks Bringing Information to People, INFOCOM '95. Fourteenth Annual Joint Conference of the IEEE Computer and Communications Societies Minimizing the disaster risk in optical telecom networks, pp.1316-1325, 1995. ,
Path-protection routing and wavelength assignment in WDM mesh networks under shared-risk-group constraints, Optical Networking, pp.49-60, 2001. ,
DOI : 10.1117/12.445211
Dynamic Routing in Telecommunications Networks, 1997. ,
An engineering approach to computer networking: ATM networks, the Internet, 590 and the telephone network ,
Reduction of blocking in arbitrary meshed WDM networks through a biased routing approach, in: Optical Fiber Communication Conference and Exhibit, 1998. OFC'98, p.94, 1998. ,
Traffic engineering approach to path selection in optical burst switching networks, Journal of Optical Networking, vol.4, issue.11, pp.759-777, 2005. ,
DOI : 10.1364/JON.4.000759
An overview of routing methods in optical burst switching networks, Optical Switching and Networking, vol.7, issue.2, pp.41-53, 2010. ,
DOI : 10.1016/j.osn.2010.01.001
A review of routing strategies for optical burst switched networks, International Journal of Communication Systems, vol.28, issue.4 ,
DOI : 10.1109/JSAC.2010.100504
Intercycle switching (ICS)-based dynamic reconfiguration of p-cycle for dual-failure survivability of WDM networks, Photonic Network Communications, vol.17, issue.2, pp.160-165, 2012. ,
DOI : 10.1109/ICC.2003.1204626
Dynamic routing and wavelength assignment in multifiber WDM networks with sparse wavelength conversion, 2012 International Conference on ICT Convergence (ICTC), pp.567-572, 2012. ,
DOI : 10.1109/ICTC.2012.6387201
A novel multi-link fault-tolerant algorithm for survivability in multi-domain optical networks post-optimization method for the routing and wavelength assignment problem applied to scheduled lightpath demands, Photonic Network Communications European Journal of Operational Research, vol.24, issue.2 ,
Binary quadratic programming formulation for routing and wavelength assignment problem in all-optical WDM networks, Optical Switching 615 and Networking, pp.354-365, 2013. ,
DOI : 10.1016/j.osn.2013.05.002
Routing and Wavelength Assignment in Optical Networks from Maximum Edge-Disjoint Paths, Genetic and Evolutionary Computing of Advances in Intelligent Systems and Computing, pp.95-103, 2014. ,
DOI : 10.1007/978-3-319-01796-9_10
Routing and wavelength assignment for establishing dependable connec- 620 tions in WDM networks, Fault-Tolerant Computing Digest of Papers. Twenty-Ninth Annual International Symposium on, pp.94-101, 1999. ,
Lightpath restoration in WDM optical networks, Network, pp.24-32, 2000. ,
Fault tolerance in survivable WDM optical networks using hybrid scheme: An analytical approach, TENCON 2009, 2009 IEEE Region 10 Conference, pp.1-6, 2009. ,
DOI : 10.1109/TENCON.2009.5395871
Fault tolerant congestion based algorithms in OBS 630 network, International Journal of Engineering (IJE), vol.5, issue.5 ,
A column generation-based heuristic for the GRWA with protection and QoS in WDM optical networks, 2013 IEEE Symposium on Computers and Communications (ISCC), pp.922-000927, 2013. ,
DOI : 10.1109/ISCC.2013.6755067
Strategies for enhanced dual failure restorability with 635 static or reconfigurable p-cycle networks, IEEE International Conference on, pp.1628-1633, 2004. ,
Mesh-Restorable Networks with Enhanced Dual-Failure Restorability Properties, Photonic Network Communications, vol.6, issue.10, pp.7-18, 2005. ,
DOI : 10.1007/s11107-005-4528-z
Alternate strategies for dual failure restoration using p- 640 cycles, ICC'06. IEEE International Conference on, pp.2477-2482, 2006. ,
Dual-link failure covering in DWDM optical networks using genetic algorithms, 2010 12th International Conference on Transparent Optical Networks, pp.1-4, 2010. ,
DOI : 10.1109/ICTON.2010.5549104
Fault-tolerant routing and wavelength assignment algorithm for multiple link failures in wavelength-routed all-optical WDM networks, Optik - International Journal for Light and Electron Optics, vol.122, issue.2, pp.110-113, 2011. ,
DOI : 10.1016/j.ijleo.2009.11.014
A mixed connection recovery strategy for surviving dual link failure in WDM networks, Optical Fiber Technology, vol.19, issue.2, pp.154-161, 2013. ,
DOI : 10.1016/j.yofte.2012.12.004
Disaster-aware data-center and content placement in cloud networks, 2013 IEEE International Conference on Advanced Networks and Telecommunications Systems (ANTS), pp.650-2013, 2013. ,
DOI : 10.1109/ANTS.2013.6802881
Survivability in optical networks, Proceedings of the 35th Southeastern Symposium on System Theory, 2003., pp.6-10, 2003. ,
DOI : 10.1109/SSST.2003.1194519
Performance Analysis of Circuit Switched Multi-Service Multi-Rate Networks With Alternative Routing, Journal of Lightwave Technology, vol.32, issue.2 ,
DOI : 10.1109/JLT.2013.2289925
Capacity Efficiency and Restorability of Path Protection and Rerouting in WDM Networks Subject to Dual Failures, Photonic Network Communications, vol.8, issue.2, pp.191-207, 2004. ,
DOI : 10.1023/B:PNET.0000033978.22198.6f
A review of fault management in WDM mesh networks: basic concepts and research challenges, IEEE Network, vol.18, issue.2, pp.41-48, 2004. ,
DOI : 10.1109/MNET.2004.1276610
Optimal configuration of p-cycles in WDM networks, 2002 IEEE International Conference on Communications. Conference Proceedings. ICC 2002 (Cat. No.02CH37333), pp.2761-2765, 2002. ,
DOI : 10.1109/ICC.2002.997345
Dynamic versus static wavelength-routed optical networks, Lightwave Technology, Journal, vol.26, issue.20, pp.3403-3415, 2008. ,
DOI : 10.1109/jlt.2008.925718
Fast and Effective Dimensioning Algorithm for End-to-End Optical Burst Switching Networks with ON-OFF Traffic Model, pp.378-387, 2007. ,
DOI : 10.1007/978-3-540-72731-6_41
Blocking evaluation and analysis of dynamic WDM networks under heterogeneous on/off traffic, Optical Switching and Networking Optimal Routing for Minimum Wavelength Requirements in End-to-End Optical Burst Switching Rings, pp.35-45, 2007. ,
Joint routing and dimensioning of optical burst switching networks, Photonic Network Communications, vol.34, issue.8, pp.266-276, 2009. ,
DOI : 10.1109/JLT.2004.836809
