On the Two-Level Uncapacitated Facility Location Problem, INFORMS Journal on Computing, vol.8, issue.3, pp.289-301, 1996. ,
DOI : 10.1287/ijoc.8.3.289
URL : https://hal.archives-ouvertes.fr/hal-01255629
Branching rules revisited, Operations Research Letters, vol.33, issue.1, pp.42-54, 2005. ,
DOI : 10.1016/j.orl.2004.04.002
The volume algorithm: producing primal solutions with a subgradient method, Mathematical Programming, vol.87, issue.3, pp.385-399, 2000. ,
DOI : 10.1007/s101070050002
Near-optimal solutions to large-scale facility location problems, Discrete Optimization, vol.2, issue.1, pp.35-50, 2005. ,
DOI : 10.1016/j.disopt.2003.03.001
URL : https://doi.org/10.1016/j.disopt.2003.03.001
Discrete and Fractional Programming Techniques for Location Models, 1995. ,
DOI : 10.1007/978-1-4615-4072-4
A general model for the uncapacitated facility and depot location problem, Location Science, vol.2, issue.3, pp.173-191, 1994. ,
URL : https://hal.archives-ouvertes.fr/hal-01255634
An approximation algorithm for the maximization version of the two level uncapacitated facility location problem, Operations Research Letters, vol.29, issue.4, pp.155-161, 2001. ,
DOI : 10.1016/S0167-6377(01)00087-6
Upper and lower bounds for the two-level simple plant location problem, Annals of Operations Research, vol.86, issue.0, pp.117-140, 1999. ,
DOI : 10.1023/A:1018942415824
Solving semidefinite quadratic problems within nonsmooth optimization algorithms, Computers & Operations Research, vol.23, issue.11, pp.1099-1118, 1996. ,
DOI : 10.1016/0305-0548(96)00006-8
About Lagrangian Methods in Integer Optimization, Annals of Operations Research, vol.3, issue.2, pp.163-193, 2005. ,
DOI : 10.1007/BFb0120690
A dual-based optimization procedure for the two-echelon uncapacitated facility location problem, Naval Research Logistics, vol.28, issue.2, pp.191-212, 1992. ,
DOI : 10.1016/S0167-5060(08)70728-3
Formulations and relaxations for a multi-echelon capacitated location???distribution problem, Computers & Operations Research, vol.36, issue.5, pp.1335-1355, 2009. ,
DOI : 10.1016/j.cor.2008.02.009
URL : https://hal.archives-ouvertes.fr/hal-00832045
Primal-Dual Variable Neighborhood Search for the Simple Plant-Location Problem, INFORMS Journal on Computing, vol.19, issue.4, pp.552-564, 2007. ,
DOI : 10.1287/ijoc.1060.0196
URL : http://bura.brunel.ac.uk/bitstream/2438/6678/2/Fulltext.pdf
A Plant and Warehouse Location Problem, Journal of the Operational Research Society, vol.28, issue.3, pp.547-554, 1977. ,
DOI : 10.1057/jors.1977.104
Computationally difficult instances for the uncapacitated facility location problem Metaheuristics: Progress as Real Problem Solvers, Operations ResearchComputer Science Interfaces Series, vol.32, pp.351-367, 2005. ,
DOI : 10.1007/0-387-25383-1_16
On the exact solution of large-scale simple plant location problems, European Journal of Operational Research, vol.39, issue.2, pp.157-173, 1989. ,
DOI : 10.1016/0377-2217(89)90189-6
The simple plant location problem: Survey and synthesis, European Journal of Operational Research, vol.12, issue.1, pp.36-81, 1983. ,
DOI : 10.1016/0377-2217(83)90181-9
New facets for the two-stage uncapacitated facility location polytope, Computational Optimization and Applications, vol.12, issue.10, pp.487-519, 2009. ,
DOI : 10.1002/j.1538-7305.1985.tb00032.x
An Exact Cooperative Method for the Simple Plant Location Problem, 2012. ,
DOI : 10.1007/s12532-014-0065-z
A branch and bound algorithm for the two-level uncapacitated facility location problem with some side constraints, European Journal of Operational Research, vol.18, issue.3, pp.349-358, 1984. ,
DOI : 10.1016/0377-2217(84)90156-5
Approximating the two-level facility location problem via a quasi-greedy approach, Mathematical Programming, vol.30, issue.1, pp.159-176, 2006. ,
DOI : 10.1287/mnsc.23.8.789
