Parametrizing turbulent exchange over summer sea ice and the marginal ice zone, Quarterly Journal of the Royal Meteorological Society, vol.11, issue.C11, pp.927-943, 2010. ,
DOI : 10.1029/GM085p0443
Numerical Simulations of Air???Sea Interaction under High Wind Conditions Using a Coupled Model: A Study of Hurricane Development, Monthly Weather Review, vol.128, issue.7, pp.2190-2210, 2000. ,
DOI : 10.1175/1520-0493(2000)128<2190:NSOASI>2.0.CO;2
On the numerical stability of surface???atmosphere coupling in weather and climate models, Geoscientific Model Development, vol.10, issue.2, pp.977-989, 2017. ,
DOI : 10.5194/gmd-9-1125-2016
URL : https://hal.archives-ouvertes.fr/hal-01406623
The parametrization of surface fluxes in large-scale models under free convection, Quarterly Journal of the Royal Meteorological Society, vol.90, issue.522, pp.255-270, 1995. ,
DOI : 10.1002/qj.49711951103
Climatologically Significant Effects of Some Approximations in the Bulk Parameterizations of Turbulent Air???Sea Fluxes, Journal of Physical Oceanography, vol.47, issue.1, pp.5-28, 2017. ,
DOI : 10.1175/JPO-D-16-0169.1
Drag coefficient reduction at very high wind speeds, Journal of Geophysical Research, vol.10, issue.C3, p.111, 2006. ,
DOI : 10.1061/40604(273)51
URL : http://onlinelibrary.wiley.com/doi/10.1029/2005JC003114/pdf
Generalized Sobol sensitivity indices for dependent variables: numerical methods, Journal of Statistical Computation and Simulation, vol.1, issue.7, pp.1-28, 2014. ,
DOI : 10.1214/aos/1013203451
URL : https://hal.archives-ouvertes.fr/hal-00801628
Stability of algorithms for a two domain natural convection problem and observed model uncertainty, Computational Geosciences, vol.27, issue.43???44, pp.509-527, 2011. ,
DOI : 10.1137/040615201
The ERA-Interim reanalysis: configuration and performance of the data assimilation system, Quarterly Journal of the Royal Meteorological Society, vol.91, issue.656, pp.553-597, 2011. ,
DOI : 10.1175/2008MWR2781.1
On the Dependence of Sea Surface Roughness on Wave Development, Journal of Physical Oceanography, vol.23, issue.9, pp.2143-2149, 1993. ,
DOI : 10.1175/1520-0485(1993)023<2143:OTDOSS>2.0.CO;2
On the Exchange of Momentum over the Open Ocean, Journal of Physical Oceanography, vol.43, issue.8, pp.431589-1610, 2013. ,
DOI : 10.1175/JPO-D-12-0173.1
On the turbulent fluxes of buoyancy, heat and moisture at the air-sea interface at low wind speeds, Journal of Geophysical Research, vol.5, issue.C12, pp.9622043-22048, 1991. ,
DOI : 10.1017/S0022112059000167
Convective profile constants revisited. blm, pp.495-515, 2000. ,
DOI : 10.1023/a:1002452529672
Recent progress and review of Physics Dynamics Coupling in geophysical models, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01323768
Non-dimensional wind and temperature profiles in the atmospheric surface layer: a re-evalutation, Boundary-layer Meteorol, vol.42, pp.55-78, 1988. ,
The LMDZ4 general circulation model: climate performance and sensitivity to parametrized physics with emphasis on tropical convection, Climate Dynamics, vol.19, issue.16, pp.3445-3482, 2006. ,
DOI : 10.1034/j.1600-0889.2003.00004.x
URL : https://hal.archives-ouvertes.fr/hal-00113202
Package 'sensitivity' The Comprehensive R Archive Network, 2015. ,
Simplified and Regular Physical Parameterizations for Incremental Four-Dimensional Variational Assimilation, Monthly Weather Review, vol.127, issue.1, pp.26-45, 1999. ,
DOI : 10.1175/1520-0493(1999)127<0026:SARPPF>2.0.CO;2
Stability-dependent exchange coefficients for airsea fluxes, Journal of Atmospheric and Oceanic Technology, issue.7, pp.221080-1094, 2005. ,
DOI : 10.1175/jtech1747.1
Air-sea bulk transfer coefficients in diabatic conditions, Boundary-Layer Meteorology, vol.3, issue.1, pp.91-112, 1975. ,
DOI : 10.1175/1520-0469(1967)024<0653:DMOSAS>2.0.CO;2
Impact of wind waves on the air-sea fluxes: A coupled model, Journal of Geophysical Research: Oceans, vol.118, issue.C4, pp.1217-1236, 2014. ,
DOI : 10.1002/jgrc.20296
Surface Fluxes for Practitioners of Global Ocean Data Assimilation, Ocean Weather Forecasting. An Integrated View of Oceanography, chapter 9, pp.229-270, 2006. ,
DOI : 10.1007/1-4020-4028-8_9
Analysis of Ocean-atmosphere Coupling Algorithms: Consistency and Stability, Procedia Computer Science, vol.51, issue.0, pp.512066-2075, 2015. ,
DOI : 10.1016/j.procs.2015.05.473
A parametric model of vertical eddy fluxes in the atmosphere, Boundary-Layer Meteorology, vol.93, issue.2, pp.187-202, 1979. ,
DOI : 10.1007/BF00117978
Definition of a moist entropy potential temperature: application to FIRE-I data flights, Quarterly Journal of the Royal Meteorological Society, vol.133, issue.656, pp.768-791, 2011. ,
DOI : 10.1175/MWR2997.1
URL : https://hal.archives-ouvertes.fr/meteo-00612421
Basic laws of turbulent mixing in the surface layer of the atmosphere, Contrib. Geophys. Inst. Acad. Sciences, USSR, issue.163, pp.1-187, 1954. ,
Nonlinear Formulation of the Bulk Surface Stress over Breaking Waves: Feedback Mechanisms from Air-flow Separation, Boundary-Layer Meteorology, vol.109, issue.1, p.117, 2008. ,
DOI : 10.2514/8.3713
An iterative solution of flux???profile relationships in the surface layer for regional model applications, Atmospheric Environment, vol.40, issue.35, pp.6892-6897, 2006. ,
DOI : 10.1016/j.atmosenv.2006.07.027
Reduced drag coefficient for high wind speeds in tropical cyclones, Nature, vol.131, issue.6929, pp.422279-283, 2003. ,
DOI : 10.1023/A:1015884903180
Coefficients for sea surface wind stress, heat flux, and wind profiles as a function of wind speed and temperature, Journal of Geophysical Research, vol.10, issue.C12, pp.9315467-15472, 1988. ,
DOI : 10.1175/1520-0485(1980)010<0727:WSCOSS>2.0.CO;2
Sensitivity estimates for nonlinear mathematical models, Math. Model. and Comp. Experiments, vol.1, issue.4, pp.407-414, 1993. ,
A randomized orthogonal array-based procedure for the estimation of first- and second-order Sobol' indices, Journal of Statistical Computation and Simulation, vol.3, issue.2, pp.1358-1381, 2015. ,
DOI : 10.1214/aos/1069362310
URL : https://hal.archives-ouvertes.fr/hal-00743964
TOGA COARE: The Coupled Ocean???Atmosphere Response Experiment, Bulletin of the American Meteorological Society, vol.73, issue.9, pp.1377-1416, 1992. ,
DOI : 10.1175/1520-0477(1992)073<1377:TCTCOR>2.0.CO;2
URL : http://journals.ametsoc.org/doi/pdf/10.1175/1520-0477%281992%29073%3C1377%3ATCTCOR%3E2.0.CO%3B2
