Combining Mixture Components for Clustering, Journal of Computational and Graphical Statistics, vol.19, issue.2, pp.332-352, 2010. ,
DOI : 10.1198/jcgs.2010.08111
URL : https://hal.archives-ouvertes.fr/inria-00321090
High-dimensional regression with gaussian mixtures and partially-latent response variables, Statistics and Computing, vol.19, issue.11, pp.893-911, 2015. ,
DOI : 10.1109/TNN.2008.2003467
URL : https://hal.archives-ouvertes.fr/hal-01107604
Planar segmentation from depth images using gradient of depth feature, 2012 IEEE/RSJ International Conference on Intelligent Robots and Systems, pp.4668-4674, 2012. ,
DOI : 10.1109/IROS.2012.6385521
A new approach to characterizing the relative position of two ellipses depending on one parameter, Computer Aided Geometric Design, vol.23, issue.4, pp.324-350, 2006. ,
DOI : 10.1016/j.cagd.2006.01.002
Joint Alignment of Multiple Point Sets with Batch and Incremental Expectation-Maximization, IEEE Transactions on Pattern Analysis and Machine Intelligence, 2017. ,
DOI : 10.1109/TPAMI.2017.2717829
URL : https://hal.archives-ouvertes.fr/hal-01413414
Fast plane extraction in organized point clouds using agglomerative hierarchical clustering, 2014 IEEE International Conference on Robotics and Automation (ICRA), pp.6218-6225, 2014. ,
DOI : 10.1109/ICRA.2014.6907776
Unsupervised learning of finite mixture models, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.24, issue.3, pp.381-396, 2002. ,
DOI : 10.1109/34.990138
Robust Estimation of Unbalanced Mixture Models on Samples with Outliers, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.37, issue.11, pp.2273-2285, 2015. ,
DOI : 10.1109/TPAMI.2015.2404835
CC-RANSAC: Fitting planes in the presence of multiple surfaces in range data, Pattern Recognition Letters, vol.32, issue.3, pp.403-410, 2011. ,
DOI : 10.1016/j.patrec.2010.10.009
Range image segmentation by surface extraction using an improved robust estimator, 2003 IEEE Computer Society Conference on Computer Vision and Pattern Recognition, 2003. Proceedings., 2003. ,
DOI : 10.1109/CVPR.2003.1211449
Methods for merging Gaussian mixture components Advances in Data Analysis and Classification, pp.3-34, 2010. ,
Fast Range Image Segmentation and Smoothing Using Approximate Surface Reconstruction and Region Growing, pp.61-73, 2012. ,
DOI : 10.1007/978-3-642-33932-5_7
Realtime plane segmentation using RGB-D cameras, pp.306-317, 2011. ,
An experimental comparison of range image segmentation algorithms, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.18, issue.7, pp.673-689, 1996. ,
DOI : 10.1109/34.506791
Fast and accurate plane segmentation in depth maps for indoor scenes, 2012 IEEE/RSJ International Conference on Intelligent Robots and Systems, pp.1665-1670, 2012. ,
DOI : 10.1109/IROS.2012.6385868
Using EM to learn 3D models of indoor environments with mobile robots, International Conference on Machine Learning, pp.329-336, 2001. ,
Merging Mixture Components for Clustering Through Pairwise Overlap, Journal of Computational and Graphical Statistics, vol.1, issue.1, pp.66-90, 2016. ,
DOI : 10.1080/01621459.1963.10500845
Efficient Multi-resolution Plane Segmentation of 3D Point Clouds, International Conference on Intelligent Robotics and Applications, pp.145-156, 2011. ,
DOI : 10.1016/0734-189X(89)90069-8
Geometrically consistent plane extraction for dense indoor 3D maps segmentation, 2016 IEEE/RSJ International Conference on Intelligent Robots and Systems (IROS), pp.4199-4204, 2016. ,
DOI : 10.1109/IROS.2016.7759618
MonoFusion: Real-time 3D reconstruction of small scenes with a single web camera, 2013 IEEE International Symposium on Mixed and Augmented Reality (ISMAR), pp.83-88, 2013. ,
DOI : 10.1109/ISMAR.2013.6671767
NCC-RANSAC: A Fast Plane Extraction Method for 3-D Range Data Segmentation, IEEE Transactions on Cybernetics, vol.44, issue.12, pp.2771-2783, 2014. ,
DOI : 10.1109/TCYB.2014.2316282
