Upper and Lower Bounds for the Two-Level Simple Plant Location Problem, Annals of Operations Research, vol.86, pp.117-140, 1999. ,
DOI : 10.1023/A:1018942415824
A Lagrangian-Based Branchand-Bound Algorithm for the Two-Level Uncapacitated Facility Location Problem with Single Assignment Constraints, Transportation Science ,
The simple plant location problem: Survey and synthesis, European Journal of Operational Research, vol.12, issue.1, pp.36-81, 1983. ,
DOI : 10.1016/0377-2217(83)90181-9
Lagrangian heuristics for the two-echelon, single-source, capacitated facility location problem, European Journal of Operational Research, vol.102, issue.3, pp.611-625, 1997. ,
DOI : 10.1016/S0377-2217(96)00227-5
