On the Heterogeneity Bias of Cost Matrices for Assessing Scheduling Algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Parallel and Distributed Systems Année : 2017
Assessing the performance of scheduling heuristics through simulation requires one to generate synthetic instances of tasks and machines with well-identified properties. Carefully controlling these properties is mandatory to avoid any bias. We consider the scheduling problem consisting of allocating independent sequential tasks on unrelated machines while minimizing the maximum execution time. In this problem, the instance is a cost matrix that specifies the execution cost of any task on any machine. This article proposes two measures for quantifying the heterogeneity properties of a cost matrix. An analysis of two classical methods used in the literature reveals a bias in previous studies. We propose new methods to generate instances with given heterogeneity properties and we show that heterogeneity has a significant impact on twelve heuristics.
tpds16-1.pdf (901.6 Ko) Télécharger le fichier
hal-01664636 , version 1 (15-12-2017)
  • HAL Id : hal-01664636 , version 1
Louis-Claude Canon, Laurent Philippe. On the Heterogeneity Bias of Cost Matrices for Assessing Scheduling Algorithms. IEEE Transactions on Parallel and Distributed Systems, 2017, 28 (6), pp.1675 - 1688. ⟨hal-01664636⟩
177 Consultations
295 Téléchargements
