Brief Announcement: Parallel Dynamic Tree Contraction via Self-Adjusting Computation
Dynamic algorithms are used to compute a property of some data while the data undergoes changes over time. Many dynamic algorithms have been proposed but nearly all are sequential. In this paper, we present our ongoing work on designing a parallel algorithm for the dynamic trees problem, which requires computing a property of a forest as the forest undergoes changes. Our algorithm allows insertion and/or deletion of both vertices and edges anywhere in the input and performs updates in parallel. We obtain our algorithm by applying a dynamization technique called self-adjusting computation to the classic algorithm of Miller and Reif for tree contraction.
