Rendering Deformed Speckle Images with a Boolean Model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Mathematical Imaging and Vision Année : 2018
Benoît Blaysat
  • Fonction : Auteur
Michel Grediac
  • Fonction : Auteur
  • PersonId : 866100
Rendering speckle images affected by a given deformation field is of primary importance to assess the metrological performance of displacement measurement methods used in experimental mechanics and based on digital image correlation (DIC). This article describes how to render deformed speckle images with a classic model of stochastic geometry, the Boolean model. The advantage of the proposed approach is that it does not depend on any interpolation scheme likely to bias the assessment process, and that it allows the user to render speckle images deformed with any deformation field given by an analytic formula. The proposed algorithm mimics the imaging chain of a digital camera, and its parameters are carefully discussed. A MATLAB software implementation and synthetic ground-truth datasets for assessing DIC software programs are publicly available.
specklegen_HAL.pdf (3.45 Mo) Télécharger le fichier
hal-01664997 , version 1 (15-12-2017)
Frédéric Sur, Benoît Blaysat, Michel Grediac. Rendering Deformed Speckle Images with a Boolean Model. Journal of Mathematical Imaging and Vision, 2018, 60 (5), pp.634-650. ⟨10.1007/s10851-017-0779-4⟩. ⟨hal-01664997⟩
529 Consultations
516 Téléchargements
