Improving Communication Patterns in Polyhedral Process Networks
Amelioration des schémas de communication dans les réseaux de processus polyédriques
Embedded systems performances are bounded by power consumption. The trend is to offload greedy computations on hardware accelerators as GPU, Xeon Phi or FPGA. FPGA chips combine both flexibility of programmable chips and energy-efficiency of specialized hardware and appear as a natural solution. Hardware design is long, fastidious and bug prone. Hardware compilers from high-level languages (High-level synthesis, HLS) are required to exploit all the capabilities of FPGA while satisfying tight time-to-market constraints. Compiler optimizations for parallelism and data locality restructure deeply the execution order of the processes, hence the read/write patterns in communication channels. This breaks most FIFO channels, which have to be implemented with addressable buffers. Expensive hardware is required to enforce synchronizations, which often results in dramatic performance loss. In this paper, we present an algorithm to partition the communications so that most FIFO channels can be recovered after a loop tiling, a key optimization for parallelism and data
locality. Experimental results show a drastic improvement of FIFO detection for regular kernels at the cost of (few) additional storage. As a bonus, the storage can even be reduced in some cases.
Les performances des systèmes embarqués sont limitées par la consommation électrique. La tendance est de déléguer les calculs gourmands en ressources à des accélérateurs matériels comme les GPU, les Xeon Phi ou les FPGA. Les circuits FPGA allient la flexibilité
d'un circuit programmable et l'efficacité énergétique d'un circuit spécialisé et apparaissent comme une solution naturelle. Des compilateurs de matériels à partir d'un langage haut-niveau sont requis pour exploiter au mieux les FPGA tout en remplissant les contraintes de mise sur le marché. Les optimisations de compilateur restructurent profondement les calculs et les schémas de communication (ordre de lecture/écriture). En conséquence, la plupart des canaux de communication ne sont plus des FIFOs et doivent être implémentées avec
un tableau adressable, ce qui nécessite du matériel supplémentaire pour la synchronisation. Dans ce rapport, nous présentons un
algorithme capable de partitionner les communications de sorte que la plupart des FIFO puissent être retrouvées après un tuilage de
boucles. Les résultats expérimentaux confirment la puissance de note algorithme et son faible surcoût en stockage.
