Bee+Cl@k: An implementation of lattice-based array contraction in the source-to-source translator Rose, ACM Conf. on Languages, Compilers, and Tools for Embedded Systems (LCTES'07), 2007. ,
Multi-dimensional Rankings, Program Termination, and Complexity Bounds of Flowchart Programs, International Static Analysis Symposium (SAS'10), 2010. ,
DOI : 10.1007/978-3-642-15769-1_8
URL : https://hal.archives-ouvertes.fr/inria-00523298
Optimizing remote accesses for offloaded kernels: Application to high-level synthesis for FPGA, ACM SIGDA Intl. Conference on Design, Automation and Test in Europe (DATE'13), 2013. ,
DOI : 10.7873/date.2013.127
URL : https://hal.archives-ouvertes.fr/hal-00761477
Data-aware Process Networks, Research Report RR, vol.8735, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01158726
Optimizing Affine Control With Semantic Factorizations, ACM Transactions on Architecture and Code Optimization, vol.14, issue.4, p.27, 2017. ,
DOI : 10.1109/CODES-ISSS.2013.6659002
URL : https://hal.archives-ouvertes.fr/hal-01470873
Efficient code generation for automatic parallelization and optimization, Second International Symposium on Parallel and Distributed Computing, 2003. Proceedings., pp.13-14, 2003. ,
DOI : 10.1109/ISPDC.2003.1267639
URL : http://www.lri.fr/~bastoul/research/papers/Bas03-ISPDC.pdf
A practical automatic polyhedral parallelizer and locality optimizer, Proceedings of the ACM SIGPLAN 2008 Conference on Programming Language Design and Implementation, pp.101-113, 2008. ,
DOI : 10.1145/1379022.1375595
URL : http://www.cse.ohio-state.edu/~bondhugu/publications/uday-pldi08.pdf
Performance modeling for fpgas: extending the roofline model with high-level synthesis tools, International Journal of Reconfigurable Computing, 2013. ,
Dataflow analysis of array and scalar references, International Journal of Parallel Programming, vol.24, issue.4, pp.23-53, 1991. ,
DOI : 10.1145/360827.360844
URL : http://www.prism.uvsq.fr/public/paf/dataflow.ps
The omega calculator and library, version 1.1. 0, p.18, 1996. ,
Polybench: The polyhedral benchmark suite URL: http://www. cs. ucla, 2012. ,
Generation of efficient nested loops from polyhedra, International Journal of Parallel Programming, vol.28, issue.5, pp.469-498, 2000. ,
DOI : 10.1023/A:1007554627716
Compiling nested loop programs to process networks, 2007. ,
DOI : 10.1145/1023833.1023864
URL : http://ptolemy.eecs.berkeley.edu/~kienhuis/ftp/cases04.pdf
Realizations of the extended linearization model. Domain-specific processors: systems, architectures, modeling, and simulation, pp.171-191, 2002. ,
Classifying interprocess communication in process network representation of nested-loop programs, ACM Transactions on Embedded Computing Systems, vol.6, issue.2, p.13, 2007. ,
DOI : 10.1145/1234675.1234680
Enabling automatic pipeline utilization improvement in polyhedral process network implementations, Application-Specific Systems, Architectures and Processors (ASAP), 2012 IEEE 23rd International Conference on, pp.173-176, 2012. ,
isl: An Integer Set Library for the Polyhedral Model, ICMS, pp.299-302, 2010. ,
DOI : 10.1007/978-3-642-15582-6_49
Handbook of Signal Processing Systems, Polyhedral Process Networks, pp.931-965, 2010. ,
Solving out of order communication using cam memory; an implementation, 13th Annual Workshop on Circuits, Systems and Signal Processing, 2002. ,
