Location of Stations in a One-Way Electric Car Sharing System
We introduce a strategic decision problem in a one-way electric car sharing system. We propose a mixed integer linear programming formulation for solving this problem. We conduct an extensive computational study to test the performance of our formulation and its relaxations by using real data instances. The results turn out to be encouraging for diving into more challenging extensions of the problem under consideration.
