Models for the piecewise linear unsplittable multicommodity flow problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue European Journal of Operational Research Année : 2017
In this paper, we consider multicommodity flow problems, with unsplit-table flows and piecewise linear routing costs. We first focus on the case where the piecewise linear routing costs are convex. We show that this problem is N P-hard for the general case, but polynomially solvable when there is only one commodity. We then propose a strengthened mixed-integer programming formulation for the problem. We show that the linear relaxation of this formulation always gives the optimal solution of the problem for the single commodity case. We present a wide array of computational experiments, showing this formulation also produces very tight linear programming bounds for the multi-commodity case. Finally, we also adapt our formulation for the non-convex case. Our experimental results imply that the linear programming bounds for this case, are only slightly than the ones of state-of-the-art models for the splittable flow version of the problem.
PUMF.pdf (448.24 Ko) Télécharger le fichier
hal-01665610 , version 1 (21-12-2017)
Bernard Fortz, Luís Gouveia, Martim Joyce-Moniz. Models for the piecewise linear unsplittable multicommodity flow problems. European Journal of Operational Research, 2017, 261 (1), pp.30 - 42. ⟨10.1016/j.ejor.2017.01.051⟩. ⟨hal-01665610⟩
191 Consultations
557 Téléchargements
