Time-dependent combined network design and routing optimization, 2014 IEEE International Conference on Communications (ICC), 2014. ,
DOI : 10.1109/ICC.2014.6883472
URL : https://hal.archives-ouvertes.fr/hal-01255249
Methods for time-dependent combined network design and routing optimization, 2014 IEEE Global Communications Conference, pp.1303-1309, 2014. ,
DOI : 10.1109/GLOCOM.2014.7036988
URL : https://hal.archives-ouvertes.fr/hal-01255248
Internet traffic engineering by optimizing ospf weights Nineteenth annual joint conference of the IEEE computer and communications societies, Proceedings. IEEE, vol.2, pp.519-528, 2000. ,
Increasing Internet Capacity Using Local Search, Computational Optimization and Applications, vol.29, issue.1, pp.13-48, 2004. ,
DOI : 10.1023/B:COAP.0000039487.35027.02
URL : https://hal.archives-ouvertes.fr/hal-01255580
Communication nets: stochastic message flow and delay, pp.48-60, 1977. ,
A bundle-type algorithm for routing in??telecommunication data networks, Computational Optimization and Applications, vol.1, issue.4, pp.385-409, 2007. ,
DOI : 10.1287/ijoc.4.3.235
Routing, Flow, and Capacity Design in Communication and Computer Networks, 2004. ,
How Well Do Traffic Engineering Objective Functions Meet TE Requirements?, Proceedings of IFIP Networking, 2006. ,
DOI : 10.1145/1111322.1111341
Comparison of different qos-oriented objectives for multicommodity flow routing optimization, Proceedings of the International Conference on Telecommunications, 2006. ,
Dynamic anticipatory routing in circuitswitched telecommunications networks, Handbook of Genetic Algorithms, vol.11, pp.229-340, 1991. ,
Using Branch-and-Price-and-Cut to Solve Origin-Destination Integer Multicommodity Flow Problems, Operations Research, vol.48, issue.2, pp.318-326, 2000. ,
DOI : 10.1287/opre.48.2.318.12378
Comparing branch-and-price algorithms for the unsplittable multicommodity flow problem, in: International Network Optimization Conference, pp.7-12, 2003. ,
On the minimum cost multiple-source unsplittable flow problem, RAIRO - Operations Research, vol.2, issue.3, pp.253-273, 2007. ,
DOI : 10.1287/moor.2.1.66
A column generation algorithm for bandwidth packing, Telecommunication Systems, vol.33, issue.1, pp.185-195, 1993. ,
DOI : 10.1007/BF02109857
An Integer Programming Approach to the Bandwidth Packing Problem, Management Science, vol.42, issue.9, pp.1277-1291, 1996. ,
DOI : 10.1287/mnsc.42.9.1277
A solving method for singly routing traffic demand in telecommunication networks, Annales des télécommunications, vol.56, pp.140-149, 2001. ,
On splittable and unsplittable flow capacitated network design arc-set polyhedra, Mathematical Programming, vol.92, issue.2, pp.315-333, 2002. ,
DOI : 10.1007/s101070100269
Unsplittable non-additive capacitated network design using set functions polyhedra, Computers & Operations Research, vol.66, pp.105-115, 2016. ,
DOI : 10.1016/j.cor.2015.08.009
Solving the Capacitated Local Access Network Design Problem, INFORMS Journal on Computing, vol.20, issue.2, pp.243-254, 2008. ,
DOI : 10.1287/ijoc.1070.0237
URL : http://www.gsia.cmu.edu/andrew/ravi/public/ijoc08.pdf
A Comparison of Mixed-Integer Programming Models for Nonconvex Piecewise Linear Cost Minimization Problems, Management Science, vol.49, issue.9, pp.1268-1273, 2003. ,
DOI : 10.1287/mnsc.49.9.1268.16570
Variable Disaggregation in Network Flow Problems with Piecewise Linear Costs, Operations Research, vol.55, issue.1, pp.146-157, 2007. ,
DOI : 10.1287/opre.1060.0314
URL : http://www.unipa.it/Odysseus/Odysseus2003_file/odysseus-main_file/pdf/CroxtonGendronMagnanti.pdf
A composite algorithm for a concave-cost network flow problem, Networks, vol.14, issue.2, pp.175-202, 1989. ,
DOI : 10.1007/BFb0120690
Reformulations by Discretization for Piecewise Linear Integer Multicommodity Network Flow Problems, Transportation Science, vol.51, issue.2, 2014. ,
DOI : 10.1287/trsc.2015.0634
Single-source unsplittable flow, Proceedings of 37th Conference on Foundations of Computer Science, pp.68-77, 1996. ,
DOI : 10.1109/SFCS.1996.548465
URL : http://www.cs.cornell.edu/home/kleinber/focs96-uf.ps
Reducibility among combinatorial problems, 1972. ,
DOI : 10.1007/978-3-540-68279-0_8
On the convex piecewise linear unsplittable multicommodity flow problem, 2016 12th International Conference on the Design of Reliable Communication Networks (DRCN), pp.9-13, 2016. ,
DOI : 10.1109/DRCN.2016.7470829
URL : https://hal.archives-ouvertes.fr/hal-01410555
Integer programming, 1998. ,
SNDlib 1.0? Survivable Network Design Library, extended version accepted in Networks, Proceedings of the 3rd International Network Optimization Conference Spa, Belgium, 2007. ,
Multipath Routing from a Traffic Engineering Perspective: How Beneficial Is It?, 2014 IEEE 22nd International Conference on Network Protocols, pp.143-154, 2014. ,
DOI : 10.1109/ICNP.2014.34
URL : http://sce.umkc.edu/~dmedhi/papers/lmpm-icnp-2014.pdf
