System-Oriented Reliability-Based Methodology for Optimal Joint Maintenance and Production Planning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
I. Roda
  • Fonction : Auteur
  • PersonId : 991434
M. Macchi
  • Fonction : Auteur
  • PersonId : 991431
C. Parmigiani
  • Fonction : Auteur
  • PersonId : 1025065
A. A. Arata
  • Fonction : Auteur
  • PersonId : 1025066
The integration among the organizational functions managing assets along its lifecycle is a crucial aspect for production companies to implement Asset Management. In this paper, an iterative four-step methodology is presented to support the joint maintenance and production planning considering the system configuration optimization as well. The objective is to overcome the limitations of most of the approaches that can be found in the literature regarding joint optimization models, by integrating it with a system-oriented and reliability-based approach. Reliability, Maintainability and Availability analysis at system level is used to support the traditional joint optimization models. The methodology is applied in an industrial case in the mining sector.
456370_1_En_11_Chapter.pdf (624.62 Ko) Télécharger le fichier
hal-01666159 , version 1 (18-12-2017)
Paternité
I. Roda, M. Macchi, C. Parmigiani, A. A. Arata. System-Oriented Reliability-Based Methodology for Optimal Joint Maintenance and Production Planning. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2017, Hamburg, Germany. pp.92-100, ⟨10.1007/978-3-319-66923-6_11⟩. ⟨hal-01666159⟩
61 Consultations
69 Téléchargements
