What is engineering asset management? " Definitions, Concepts and Scope of Engineering Asset Management, pp.3-16, 2010. ,
Maintenance within physical asset management Evaluating the life cycle costs of plant assets: A multidimensional view Maintenance in Manufacturing Environment : An Overview Integrated Maintenance Planning Studying the funding principles for integrating Asset Management in Operations: an empirical research in production companies, Maintenance and Production: A Review of Planning Models, " Complex System Maintenance Handbook, pp.287-298, 2002. ,
Joint consideration of production scheduling, maintenance and quality policies: a review and conceptual framework Resolution of joint maintenance/ production scheduling by sequential and integrated strategies Interactions of maintenance and production planning for multipurpose process plants -a system effectiveness approach, Int. J. Adv. Oper. Manag. Artif. Neural Nets Probl. Solving Methods Ind. Eng. Chem. Res, vol.212, issue.40, pp.782-789, 2001. ,
Integrated optimal reliable design, production, and maintenance planning for multipurpose process plants Buffer allocation, machine selection and preventive maintenance optimization in unreliable production lines, Proc. 2015 Int. Conf. Ind. Eng. Syst. Manag. IEEE IESM 2015, pp.1543-1555, 2003. ,
Simulation as a tool for life cycle cost analysis, 2008 Winter Simulation Conference, pp.2497-2503, 2008. ,
DOI : 10.1109/WSC.2008.4736359
URL : http://www.informs-sim.org/wsc08papers/312.pdf
Application of a performance -driven TCO evaluation model for physical asset management, 9th WCEAM Research Papers, pp.11-23, 2015. ,
Introducing buffer inventories in the RBD analysis of process production systems, Reliability Engineering & System Safety, vol.104, pp.84-95, 2012. ,
DOI : 10.1016/j.ress.2012.03.015
