Abstract : Promising developments and further improvements of cyber physical logistics systems (CPLS) and automated guided vehicles (AGV) lead to broader application of such systems in production environments and smart factories. In this study a new mixed integer linear program (MILP) is presented for the scheduling of AGVs in a flexible reentrant job shop with blocking. Optimal solutions to small instances of the complex scheduling problem in a make-to-order production, minimizing the make span, are calculated. Different numbers of jobs are considered. Feasible schedules for the machines and the AGVs are generated from different sized instances to evaluate the limits of the mathematical model.
https://hal.inria.fr/hal-01666164 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Monday, December 18, 2017 - 10:38:18 AM Last modification on : Monday, December 18, 2017 - 11:02:27 AM
Jens Heger, Thomas Voss. Optimal Scheduling for Automated Guided Vehicles (AGV) in Blocking Job-Shops. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2017, Hamburg, Germany. pp.151-158, ⟨10.1007/978-3-319-66923-6_18⟩. ⟨hal-01666164⟩
