A Framework for Integrated Proactive Maintenance Decision Making and Supplier Selection - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The increasing use of sensors in manufacturing enterprises has led to the need for real-time data-driven information systems capable of processing huge amounts of data in order to provide meaningful insights about the actual and the predicted business performance. We propose a framework for real-time, event-driven proactive supplier selection driven by Condition Based Maintenance (CBM). The proposed framework was tested in a real in automotive lighting equipment scenario.
456370_1_En_49_Chapter.pdf (605.38 Ko) Télécharger le fichier
hal-01666189 , version 1 (18-12-2017)
Paternité
Alexandros Bousdekis, Nikos Papageorgiou, Babis Magoutas, Dimitris Apostolou, Gregoris Mentzas. A Framework for Integrated Proactive Maintenance Decision Making and Supplier Selection. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2017, Hamburg, Germany. pp.416-424, ⟨10.1007/978-3-319-66923-6_49⟩. ⟨hal-01666189⟩
109 Consultations
110 Téléchargements
