A Framework for Integrated Proactive Maintenance Decision Making and Supplier Selection
The increasing use of sensors in manufacturing enterprises has led to the need for real-time data-driven information systems capable of processing huge amounts of data in order to provide meaningful insights about the actual and the predicted business performance. We propose a framework for real-time, event-driven proactive supplier selection driven by Condition Based Maintenance (CBM). The proposed framework was tested in a real in automotive lighting equipment scenario.
