Abstract : “The most profound technologies are those that disappear… They weave themselves into the fabric of everyday life until they are indistinguishable from it” wrote computer scientist and visionary Mark Weiser nearly 25 years ago in his essay “The Computer for the 21st Century.” It turns out he was right: in the age of “Industry 4.0”, digital technologies are the core driver for the manufacturing transformation. In fact, the introduction of such technologies allows companies to find solutions capable to turn increasing complexity into opportunities for ensuring sustainable competitiveness and profitable growth. Nonetheless, the effective implementation in manufacturing still depends on the state of practice: it may slow down, or even worst, may prevent from implementation. Indeed, we assume that a minimum level of capabilities is required before implementing the digital technologies in a company. Based on this concern, our research question is “are manufacturing companies ready to go digital?”. This paper wants to illustrate a “tool” to answer this question by building a maturity assessment method to measure the digital readiness of manufacturing firms. Based on the inspiring principles of the CMMI (Capability Maturity Model Integration) framework, we propose a model to set the ground for the investigation of company digital maturity. Different dimensions are used to assess 5 areas in which manufacturing key processes can be grouped: (1) design and engineering, (2) production management, (3) quality management, (4) maintenance management and (5) logistics management. Thus, the maturity model provides a normative description of practices in each area and dimension, building a ranked order of practices (i.e. from low to high maturity). A scoring method for maturity assessment is subsequently defined, in order to identify the criticalities in implementing the digital transformation and to subsequently drive the improvement of the whole system. The method should be useful both to manufacturing companies and researchers interested in understanding the digital readiness level in the state of practice.
https://hal.inria.fr/hal-01666224 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Monday, December 18, 2017 - 10:41:28 AM Last modification on : Tuesday, August 13, 2019 - 11:10:03 AM
Anna De Carolis, Marco Macchi, Elisa Negri, Sergio Terzi. A Maturity Model for Assessing the Digital Readiness of Manufacturing Companies. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2017, Hamburg, Germany. pp.13-20, ⟨10.1007/978-3-319-66923-6_2⟩. ⟨hal-01666224⟩
