Positive recurrence of processes associated to crystal growth models. The Annals of Applied Probability, pp.1059-1085, 2006. ,
Balls into Bins via Local Search, Proceedings of the Twenty-Fourth Annual ACM-SIAM Symposium on Discrete Algorithms, pp.16-34, 2013. ,
DOI : 10.1137/1.9781611973105.2
URL : http://www.mpi-inf.mpg.de/~hsun/1207.2125v1.pdf
Systèmes de particules en interaction et modèles de déposition aléatoire ,
Some results about ergodicity in shape for a crystal growth model, Electronic Journal of Probability, vol.18, issue.0, pp.1-20, 2013. ,
DOI : 10.1214/EJP.v18-2177
URL : https://hal.archives-ouvertes.fr/hal-00817273
The Power of Two Choices on Graphs, ACM SIGMETRICS Performance Evaluation Review, vol.43, issue.2, pp.69-71, 2015. ,
DOI : 10.1038/nature04605
URL : https://hal.archives-ouvertes.fr/hal-01199271
Markov models of steady crystal growth. The Annals of Applied Probability, pp.339-355, 1993. ,
DOI : 10.1214/aoap/1177005427
Balanced allocation on graphs, Proceedings of the seventeenth annual ACM-SIAM symposium on Discrete algorithm , SODA '06, pp.434-443, 2006. ,
DOI : 10.1145/1109557.1109606
URL : http://arxiv.org/pdf/cs/0510086
Criteria for the recurrence or transience of stochastic process. I, Journal of Mathematical Analysis and Applications, vol.1, issue.3-4, pp.314-330, 1960. ,
DOI : 10.1016/0022-247X(60)90005-6
The power of two choices in randomized load balancing, IEEE Transactions on Parallel and Distributed Systems, vol.12, issue.10, 1996. ,
DOI : 10.1109/71.963420
Stochastic networks and queues, 2013. ,
DOI : 10.1007/978-3-662-13052-0
Queueing system with selection of the shortest of two queues: An asymptotic approach, Problemy Peredachi Informatsii, vol.32, issue.1, pp.20-34, 1996. ,
plugging f (n + e i ) = 1 ni=j?1 and f (n ? e i ) = 1 ni=j+1 in equation (4) gives, first for j = 0, Lf (n) = ??, pp.0-0 ,
