Positive recurrence of processes associated to crystal growth models, Annals of Applied Probability, pp.1059-1085, 2006. ,
The power-series algorithm applied to the shortest-queue model, Operations Research, vol.40, issue.1, pp.157-167, 1992. ,
Balls into bins via local search, Proceedings of the Twenty-Fourth Annual ACM-SIAM Symposium on Discrete Algorithms, pp.16-34, 2013. ,
Systèmes de particules en interaction et modèles de déposition aléatoire, 2012. ,
Some results about ergodicity in shape for a crystal growth model, Electronic Journal of Probability, vol.18, issue.33, pp.1-20, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00817273
Alexandre Proutiere, and Florian Simatos. Load balancing via random local search in closed and open systems, In ACM SIGMETRICS Performance Evaluation Review, vol.38, pp.287-298, 2010. ,
The power of two choices on graphs: the pair-approximation is accurate?, ACM SIGMETRICS Performance Evaluation Review, vol.43, issue.2, pp.69-71, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01199271
A mean field model of work stealing in large-scale systems, ACM SIGMETRICS Performance Evaluation Review, vol.38, pp.13-24, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00788862
Markov models of steady crystal growth, Annals of Applied Probability, pp.339-355, 1993. ,
DOI : 10.1214/aoap/1177005427
URL : https://doi.org/10.1214/aoap/1177005427
Balanced allocation on graphs, Proceedings of the seventeenth annual ACM-SIAM symposium on Discrete algorithm, pp.434-443, 2006. ,
DOI : 10.1145/1109557.1109606
URL : http://arxiv.org/pdf/cs/0510086
Criteria for the recurrence or transience of stochastic process. i, Journal of Mathematical Analysis and applications, vol.1, issue.3-4, pp.314-330, 1960. ,
DOI : 10.1016/0022-247x(60)90005-6
URL : https://doi.org/10.1016/0022-247x(60)90005-6
The Power of Two Choices in Randomized Load Balancing, 1996. ,
Stochastic networks and queues, vol.52, 2013. ,
DOI : 10.1007/978-3-662-13052-0
Queueing system with selection of the shortest of two queues: An asymptotic approach, Problemy Peredachi Informatsii, vol.32, issue.1, pp.20-34, 1996. ,
, Topics in the constructive theory of countable Markov chains, 1995.
Ergodicity, continuity and analyticity of countable Markov chains, Trudy Moskovskogo Matematicheskogo Obshchestva, vol.39, pp.3-48, 1979. ,
Redundancy-d: The power of d choices for redundancy, Operations Research, vol.65, issue.4, pp.1078-1094, 2017. ,
, For k = 2m ? 1, m ? N, for n such that |n| = k ? p, n 1 = m, n j > 0 and n l > 0 with j and l distinct
