A Nonmonotone Proximal Bundle Method with (Potentially) Continuous Step Decisions, SIAM Journal on Optimization, vol.23, issue.3, pp.1784-1809, 2013. ,
DOI : 10.1137/120888867
URL : http://www.di.unipi.it/~frangio/papers/1ParamBundle.pdf
Piecewise-quadratic Approximations in Convex Numerical Optimization, SIAM Journal on Optimization, vol.21, issue.4, pp.1418-1438, 2011. ,
DOI : 10.1137/100817930
Feature selection for support vector machines using Generalized Benders Decomposition, European Journal of Operational Research, vol.244, issue.1, pp.210-218, 2015. ,
DOI : 10.1016/j.ejor.2015.01.006
Integer programming models for feature selection: New extensions and a randomized solution algorithm, European Journal of Operational Research, vol.250, issue.2, pp.389-399, 2016. ,
DOI : 10.1016/j.ejor.2015.09.051
Dimensionality reduction via sparse support vector machines, Journal of Machine Learning Research, vol.3, pp.1229-1243, 2003. ,
Feature selection via concave minimization and support vector machines, Machine Learning proceedings of the Fifteenth International Conference, pp.82-90, 1998. ,
Feature Selection via Mathematical Programming, Feature selection via Mathematical Programming, pp.209-217, 1998. ,
DOI : 10.1287/ijoc.10.2.209
URL : ftp://ftp.cs.wisc.edu/math-prog/tech-reports/95-21.ps.Z
Combining svms with various feature selection strategies, in Feature extraction, foundations and applications, I. Guyon, 2006. ,
DOI : 10.1007/978-3-540-35488-8_13
URL : http://www.csie.ntu.edu.tw/~b88052/tmp/thesis.pdf
An introduction to Support Vector Machines and other kernel-based learning methods, 2000. ,
DOI : 10.1017/CBO9780511801389
Supervised classification and mathematical optimization, Computers & Operations Research, vol.40, issue.1, pp.150-165, 2013. ,
DOI : 10.1016/j.cor.2012.05.015
A Lagrangian heuristic algorithm for the timedependent combined network design and routing problem, Networks, pp.69-110, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01428061
Solving semidefinite quadratic problems within nonsmooth optimization algorithms, Computers & Operations Research, vol.23, issue.11, pp.1099-1118, 1996. ,
DOI : 10.1016/0305-0548(96)00006-8
Generalized bundle methods for sum-functions with " easy " components: Applications to multicommodity network design, Mathematical Programming, pp.133-161, 2014. ,
DOI : 10.1007/s10107-013-0642-3
URL : http://www.di.unipi.it/~frangio/papers/GBM4DFEC.pdf
On the computational eciency of subgradient methods: a case study with lagrangian bounds, Mathematical Programming Computation, 2017. ,
On solving the Lagrangian dual of integer programs via an incremental approach, Computational Optimization and Applications, vol.169, issue.1, pp.117-138, 2009. ,
DOI : 10.1002/9781118627372
An introduction to variable and feature selection, Journal of Machine Learning Research, vol.3, pp.1157-1182, 2003. ,
Gene selection for cancer classification using support vector machines, Machine Learning, pp.389-422, 2002. ,
Convex Analysis and Minimization Algorithms II?Advanced Theory and Bundle Methods, Grundlehren Math. Wiss, vol.306, 1993. ,
DOI : 10.1007/978-3-662-06409-2
Feature selection and extraction, in Handbook of Pattern Recognition and Image Processing, 1986. ,
Classification and disease prediction via Mathematical Programming, 2009. ,
DOI : 10.1063/1.2817343
URL : http://arxiv.org/pdf/0709.0047
Penalties, Journal of Computational and Graphical Statistics, vol.16, issue.4, pp.782-798, 2007. ,
DOI : 10.1198/106186007X255676
Feature selection for Support Vector Machines via Mixed Integer Linear Programming, Information Sciences, vol.279, pp.163-175, 2014. ,
DOI : 10.1016/j.ins.2014.03.110
URL : https://hal.archives-ouvertes.fr/hal-01255519
Arbitrary-norm separating plane, Operations Research Letters, vol.24, issue.1-2, pp.15-23, 1997. ,
DOI : 10.1016/S0167-6377(98)00049-2
URL : ftp://ftp.cs.wisc.edu/math-prog/tech-reports/97-07r.ps
Information-Theoretic Feature Selection in Microarray Data Using Variable Complementarity, IEEE Journal of Selected Topics in Signal Processing, vol.2, issue.3, pp.261-274, 2008. ,
DOI : 10.1109/JSTSP.2008.923858
URL : http://www.ulb.ac.be/di/map/pmeyer/Homepage_files/Meyer08CorrectedJSTSP.pdf
Optimal feature selection for support vector machines, Pattern Recognition, vol.43, issue.3, pp.584-591, 2010. ,
DOI : 10.1016/j.patcog.2009.09.003
URL : http://www.andrew.cmu.edu/user/minhhoan/papers/SVMFeatureWeight_PR.pdf
Feature selection combining linear support vector machines and concave optimization, Optimization Methods and Software, pp.117-128, 2010. ,
DOI : 10.1080/10556780903139388
The nature of the statistical learning theory, 1995. ,
Use of the zero-norm with linear models and kernel methods, Journal of Machine Learning Research, vol.3, pp.1439-1461, 2003. ,
Feature selection for SVMs, Advances in Neural Information Processing Systems, p.12, 2000. ,
