New interface
Conference papers
Dagli strumenti di piano ai modelli: esempio di scenarizzazione delle ipotesi contenute nello Schema di Coerenza Territoriale della regione urbana di Grenoble (Francia), per un modello di uso del suolo e dei trasporti
Fausto Lo Feudo 1
1 STEEP - Sustainability transition, environment, economy and local policy
Inria Grenoble - Rhône-Alpes, LJK - Laboratoire Jean Kuntzmann
Abstract : This article describes the methodology adopted for the implementation of simulation scenarios for an Land Use and Transport Integrated model, referring to the territory of the Grenoble Urban Region, in the Isere Department in France. The assumptions behind these simulation scenarios were derived from the assumptions of residential and transportation supply evolution, at 2030, contained in the Grenoble Urban Region's Scheme of Territorial Coherence (SCOT). The SCOT is a strategic urban planning tool for the medium and long term, defining for a group of municipalities an integrated and coherent urban project, in terms of economic development, spatial and environmental planning, housing, mobility and services, and land use. Simulation scenarios serve to feed the Tranus_Grenoble model implemented in collaboration with the Urban Planning Agency of the Grenoble Urban Region (AURG), with the aim of providing an operational tool that supports the territorial analysis and the planning activity and in particular with the function of simulating the impact of policies envisaged in the SCOT and verifying its effectiveness. The article outlines the methodology behind the implementation fo simulation scenarios, the adaptation of the hypotheses contained in the Plan to the model structure and the process of treating and consolidating different databases, prospective studies, socio-economic and econometric parameters. The article illustrates the basic structure of the Tranus_Grenoble model, the features and objectives of the SCOT for the Urban Region of Grenoble, the structure of the base scenario of the model and the methodology for implementing the simulation scenarios.
Document type :
Conference papers
Complete list of metadata
Cited literature [12 references]  Display  Hide  Download
https://hal.inria.fr/hal-01666464
Contributor : Peter Sturm Connect in order to contact the contributor
Submitted on : Monday, December 18, 2017 - 1:50:46 PM
Last modification on : Friday, February 4, 2022 - 3:23:36 AM
File
LOFEUDO.pdf
Identifiers
  • HAL Id : hal-01666464, version 1
Collections
Citation
Fausto Lo Feudo. Dagli strumenti di piano ai modelli: esempio di scenarizzazione delle ipotesi contenute nello Schema di Coerenza Territoriale della regione urbana di Grenoble (Francia), per un modello di uso del suolo e dei trasporti. 2017 - XXXVIII Conferenza scientifica annuale AISRe, Sep 2017, Cagliari, Italy. pp.1-26. ⟨hal-01666464⟩
Share
Metrics
Record views
394
Files downloads
237
