A new class of uniformly accurate numerical schemes for highly oscillatory evolution equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Foundations of Computational Mathematics Année : 2020
We introduce a new methodology to design uniformly accurate methods for oscil-latory evolution equations. The targeted models are envisaged in a wide spectrum of regimes, from non-stiff to highly-oscillatory. Thanks to an averaging transformation, the stiffness of the problem is softened, allowing for standard schemes to retain their usual orders of convergence. Overall, high-order numerical approximations are obtained with errors and at a cost independent of the regime.
paperUA_final.pdf (3.23 Mo) Télécharger le fichier
hal-01666472 , version 1 (18-12-2017)
hal-01666472 , version 2 (10-01-2019)
Philippe Chartier, Mohammed Lemou, Florian Méhats, Gilles Vilmart. A new class of uniformly accurate numerical schemes for highly oscillatory evolution equations. Foundations of Computational Mathematics, 2020, 20 (1), pp.1-33. ⟨10.1007/s10208-019-09413-3⟩. ⟨hal-01666472v2⟩
463 Consultations
238 Téléchargements
