Adaptive inexact semismooth Newton methods for the contact problem between two membranes
We propose an adaptive inexact version of a class of semismooth Newton
methods. As a model problem, we study the system of variational
inequalities describing the contact between two membranes. This problem is written using a complementary formulation and discretized
with conforming finite elements, yielding a nonlinear, semismooth
(non-differentiable) algebraic system. We consider any iterative
linearization algorithm like the Newton-min or the
Newton Fischer--Burmeister which we complement
by any iterative linear algebraic solver. We then derive an a posteriori
estimate on the error between the exact solution and the approximate
solution which is valid on any step of the linearization and
algebraic resolutions. Our estimate is based on flux reconstructions
in discrete subspaces of $\mathbf{H}(\mathrm{div}, \Omega)$ and on potential reconstructions in
discrete subspaces of $H^1(\Omega)$ satisfying the constraints. It distinguishes
the discretization, linearization, and algebraic components of the error.
Consequently, we can formulate adaptive stopping criteria for both
solvers, giving rise to an adaptive version of the considered inexact
semismooth Newton algorithm. Under these criteria, the efficiency of our
estimates is also established, meaning that we prove them equivalent
with the error up to a generic constant. Numerical experiments for the
Newton-min algorithm in combination with the GMRES algebraic
solver confirm the efficiency of the developed adaptive method.
