Long-Short Range Communication Network Leveraging LoRa and Wake-up Receiver - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Microprocessors and Microsystems: Embedded Hardware Design Année : 2018
Wireless sensor and actuator networks play a central role in the Internet of Things, and a lot of effort is devoted to enable energy efficient and low latency communications. In the recent years, low power communications has evolved towards multi-kilometer ranges and low bit-rate approaches such as LoRa TM. However, the medium access layer protocols rely on the well-known duty-cycling schemes, which require a trade-off between power consumption and latency for message transfer from the gateway to the nodes. Domains such as industrial applications in which sensors and actuators are part of the control loop require predictable latency, as well as low power consumption. Emerging ultra-low-power wake-up receivers enable pure-asynchronous communications, allowing both low latency and low power consumption, but at the cost of a lower sensitivity and lower range than traditional wireless receivers and LoRa TM. In this work, we propose an energy efficient architecture that combines long-range communication with ultra low-power short-range wake-up receivers to achieve both energy efficient and low latency communication in heterogeneous long-short range networks. A hardware architecture as well as a protocol is proposed to exploit the benefits of these two communication schemes. Experimental measurements and analytical comparisons show that the proposed approach remove the need for a trade-off between power consumption and latency.
main.pdf (2.34 Mo) Télécharger le fichier
hal-01666858 , version 1 (18-12-2017)
  • HAL Id : hal-01666858 , version 1
Fayçal Ait Aoudia, Matthieu Gautier, Michele Magno, Mickaël Le Gentil, Olivier Berder, et al.. Long-Short Range Communication Network Leveraging LoRa and Wake-up Receiver. Microprocessors and Microsystems: Embedded Hardware Design , 2018, 56, pp.184-192. ⟨hal-01666858⟩
270 Consultations
1333 Téléchargements
