Unsupervised extremely randomized trees
In this paper we present a method to compute dissimilarities on unlabeled data, based on extremely randomized trees. This method, Unsupervised Extremely Randomized Trees, is used jointly with a novel randomized labeling scheme we describe here, and that we call AddCl3. Unlike existing methods such as AddCl1 and AddCl2, no synthetic instances are generated, thus avoiding an increase in the size of the dataset. The empirical study of this method shows that Unsupervised Extremely Randomized Trees with AddCl3 provides competitive results regarding the quality of resulting clusterings, while clearly outperforming previous similar methods in terms of running time.
unsupervised-extremely-randomized_Dalleau_Couceiro_Smail-Tabbone.pdf (432.71 Ko)
Télécharger le fichier
